-   -   XDi twin plug install photo required (http://forums.pelicanparts.com/911-engine-rebuilding-forum/542062-xdi-twin-plug-install-photo-required.html)
Bronco 05-12-2010 02:50 PM
Hi lads.
Just about to get into my engine rebuild and wondered if anyone had photo's of an XDi set up on a stock 3.2 motor?
Db
jwasbury 05-13-2010 05:28 AM
Not a 3.2 install (its a 3.3 turbo), but perhaps these can provide some inspiration:
DFUs mounted to firewall
http://asbury.smugmug.com/By-Land/Po...09_SqS8D-L.jpg
DFU wires bundled in wire loom pass through a hole I bored in the fire wall
http://asbury.smugmug.com/By-Land/Po...49_SZ9gm-L.jpg
XDI-2 mounted below passenger seat. For 12v power, ran a 12g wire from a relay I mounted in the front trunk compartment near the battery. This provides juice for the XDI and both DFUs (each fused separately underneath the pass. seat).
http://asbury.smugmug.com/By-Land/Po...32_3xLpL-L.jpg
peppy 05-14-2010 07:45 PM
Jacob are those nut shells in the first picture? Do you have squirrels?:D
