Pilot bearing grease
Is there a spec for how much grease to put in the pilot bearing at the fly wheel? I don't see this in the books. Or just put some in there! Its a 2.7.
Old 05-13-2010, 10:38 PM
I just put in a new bearing, and I believe they were oil/greased from the factory. It was clearly lubricated, but with a very thin grease. I added a dab of high temp grease, but am not sure it was necessary. The old pilot bearing had a lot of grease in it, and didn't turn very easily...big difference in how the new one felt...
Old 05-14-2010, 08:50 AM
LWJ LWJ is online now
Don't know about a 2.7 but on my 3.0 I greased it and made sure there was not TOO MUCH with the clutch alignment tool. There seemed to be a nice little recess behind the bearing to catch the grease. You are supposed to grease it, just watch that it doesn't ooze out and get on the flywheel.
Larry
Old 05-14-2010, 01:35 PM
