83 911SC Fuel line & sway bar help needed
2-QUESTIONS:
1. Pressure line leak(squirt) found at front of car just above the sway bar (pic attached). Can I install a pressure rated coupler/insert instead of replacing the entire fuel line?? 2. Missing front sway bar bolts & nut that attach right & left brackets to frame. Does Pelicanparts sell those?? http://forums.pelicanparts.com/uploa...1273862746.jpg http://forums.pelicanparts.com/uploa...1273862786.jpg |
I would cut out the leak and use a piece of hose and a shunt tube. Avation permatex and a couple clamps should stop the leak. If it doesnt youre only out a couple buks.
The sway bar is held to a clamp with an 8mm bolt and the support that bolts to the body is 10mm reg thread. Bruce |
| All times are GMT -8. The time now is 11:25 AM. |
