-   -   Gratuitous Clean Case Shot (http://forums.pelicanparts.com/911-engine-rebuilding-forum/544912-gratuitous-clean-case-shot.html)
Daviboy 05-28-2010 05:40 AM
Not really re-build related well kind of.... just spent last 4 hours cleaning up internals of the cases it is so satisfying to see something thats 28 years old looking so good...
http://forums.pelicanparts.com/uploa...1275050430.jpg
al lkosmal 05-28-2010 08:22 AM
Looking very nice Davy. I never get tired of seeing how nicely these clean up.
Regards,
al
Geronimo '74 05-28-2010 09:55 AM
Great job Davy!
Ready to assemble so it seems.
The case was repairable then?
Daviboy 05-28-2010 12:52 PM
Thanks guys especially Geronimo sorry about before. Yes the case came back looking great all within spec and they made a great job re-sleeving #2.
Before
http://forums.pelicanparts.com/uploa...1275075996.jpg
After
http://forums.pelicanparts.com/uploa...1275076319.jpg
LeakProof 05-28-2010 03:27 PM
Nice job Davy, you can eat off that thing!
My case was just like your's a few months ago, not as clean, but pretty close.
Here's were I'm at now, minus the fuel injection, recently installed.
http://forums.pelicanparts.com/uploa...1275085227.jpg
Leakproof.
Daviboy 05-29-2010 01:54 AM
Looking good Leakproof. I will be a while before I get to that stage. Saving for parts and shipping time means I will be off the road until about September. I am however going to keep a blog of progress
Geronimo '74 05-31-2010 10:52 AM
Wow:eek::eek: That turned out nicely!! Glad to see the case could be saved.
What did you use to get the inside this clean?? Just brake cleaner and a cloth??
Somehow I just don't see me getting my case as spotless as yours.
(no need to apologize, I overreacted too. I guess we both needed a deep breath and a 10 second time out before hitting the keyboard. ;))
Daviboy 05-31-2010 11:54 AM
Thanks Geronimo yes the machine shop made a great job on that. As far as cleaning goes after soaking with a water based engine cleaner I hit it with the steam cleaner set as high as it would go. I then hit the bearing webs with some super fine polish and the dremel with some cotton cleaning wheels. 1800 grit paper on the case seal areas. After that about 4 hours with the carb cleaner and lint free cloths. All in all about 6-8 hours cleaning the internals, took a cleaning kit for a 12 gauge and hit all the internal oil lines where the case through bolts are located. Blew through every oil passage I could find and the piston squirters.
I may be a bit anal about cleaning but after years of running and maintaining hydraulic downhole valves in the oil and gas industry I got to know that cleaning and prep work are more than half the battle. Never had a valve fail on me even at 18,000ft and 6,000 psi at 230 deg F. ;)
