1978 SC Question
I'm starting a 3.0 engine project and my core engine is of 1978 vintage. I'm finding out that 78 & 79 3.0's used a smaller eleven blade fan & fan housing. My fan is perfect but the housing has some cracks. So, I'm searching for a replacement 78-79 SC fan housing with not much luck yet.
Q: If I opt to use the larger eleven blade fan & housing, will I also need to find another shroud as well? Thanks |
No, the housing outside diameter is the same, the fan and interior housing diameter is the only smaller part.
| All times are GMT -8. The time now is 07:27 PM. |
