-   -   911 3.2 to 3.4 conversion; engine not running (http://forums.pelicanparts.com/911-engine-rebuilding-forum/545476-911-3-2-3-4-conversion-engine-not-running.html)
renders 06-13-2010 12:37 PM
So I starting checking on the electrical wiring and apparently this car has been messed with in order to pass inspections. All the wiring seems f****d up. The DME wiring harness has been modified and this FAC-2 (F****2) has been put it. I guess now I am closer to get this back to original with the 3wire O2 sensor. i will revert all this crap as I don't care too much about passing stupid CA emission nonsense. A bunch or retarded morons sitting in their chairs and thinking how to screw the public and getting paid huge tax payer $$$ to cook up this garbage.
Anyways here is how this looks:
http://forums.pelicanparts.com/uploa...1276457673.jpg
http://forums.pelicanparts.com/uploa...1276457701.jpg
I guess I also should talk to Steve Wong as I have one of his chips in my car to see if and how this affects the engine control.
For now I will take this Woodoo out and follow the manual to put this back to factory original - the way it was designed.
renders 06-13-2010 05:21 PM
Crap, the person converting the car removed the connector for the O2 sensor. So I am missing on contact in the connector. So I need to find a contact to wire the cable to the O2 sensor. I am wondering where I would find this contact to rebuild the connector.
http://forums.pelicanparts.com/uploa...1276474850.jpg
renders 06-13-2010 05:31 PM
OK. Seems those contact with the wire can be purchased from our host - good. or our
61130005197 for 0,2- 0,5MM˛ wire
61130006663 for 0.75MM˛ wire
found in this post below:
http://forums.pelicanparts.com/boxster-cayman-forum/547141-need-add-pin-motronic-harness.html
m110 05-16-2013 09:28 AM
any updates on what happened here?
renders 05-20-2013 11:12 AM
I ended up cleaning up reverting everything to factory spec, wired the missing pin into the wiring harness and connected the O2 sensor. However doesn't seem to make a big deal of difference from an emission standpoint. Motor runs great and with a CATed exhaust my emissions are fine. Everything looks neat and clean now, my engine bay and my wiring including the area under the seat. I am happy with the result.
oter919 09-06-2013 05:13 PM
call me I may be interested in buying your car
Jim Parise
916.496.2218
efhughes3 09-06-2013 07:36 PM
Originally Posted by oter919 (Post 7642899)
Jim Parise
916.496.2218
There are PM's....
