-   -   Where to get 3.6 injectors cleaned and tested (http://forums.pelicanparts.com/911-engine-rebuilding-forum/545922-where-get-3-6-injectors-cleaned-tested.html)
e3photo 06-02-2010 08:34 PM
I figured that while the engine is apart, I should send the fuel injector rails out to be cleaned and tested. Does anyone have a suggestion as to where to send them. These will be from a 96 3.6 (993)
Thanks,
Emerald
e3photo 06-03-2010 07:41 AM
Found it. Got a couple of suggestions from another board.
Witchhunter and Rc Engineering. Just in case some else is interested.
Thanks.
Emerald
175K911 06-04-2010 04:04 AM
Just had my 3.6 injectors done by WitchHunter. I've used then for my 3.2 injectors too. Good work, quick turnaround, and reasonable at $19 per injector.
BGCarrera32 06-04-2010 11:16 AM
Witchhunter did mine, had them back in a week.
rsscotty 06-04-2010 04:29 PM
When the injectors get back from being rebuilt the bodys are stripped to bare metal. If you don't take the time to paint them before install, they rust like crazy. You need some sort of fuel proof paint.
BGCarrera32 06-05-2010 01:55 PM
Yes! Good catch- my Bosch injectors went to Witchhunter black, and came back bare on the outside.
