-   -   2.0 pistons (http://forums.pelicanparts.com/911-engine-rebuilding-forum/547664-2-0-pistons.html)
safe 06-12-2010 11:13 AM
2.0 pistons
I bought a set of 2.0 liter cylinder and pistons. One piston was a little different (I know that), turns out to be a carrera 6 piston.
The "S" piston weighs 483g and the "906" 390g, including wrist pis and rings. Quite a big difference.
http://forums.pelicanparts.com/uploa...1276365662.jpg
http://forums.pelicanparts.com/uploa...1276366141.jpg
http://forums.pelicanparts.com/uploa...1276366210.jpg
The wrist pin looks trick, it tapers!
http://forums.pelicanparts.com/uploa...1276365725.jpg
http://forums.pelicanparts.com/uploa...1276365774.jpg
http://forums.pelicanparts.com/uploa...1276365860.jpg
We're looking to sell the carrera6 piston and get a standard S-piston instead. What can such a single piston be worth?
Flat6pac 06-12-2010 12:46 PM
The Carrera piston is relief cut like a 69S for the higher compression. The others that you have are 67/68 S
Bruce
safe 06-12-2010 01:24 PM
The S above are also cut for 45/39 mm valves.
304065 06-12-2010 07:43 PM
I wouldn't be surprised if the taper were for pin lightening, the pin is probably the same diameter on the outside. Cool find!
ajserrano 07-13-2014 10:45 PM
Hello Magnus, if you still have that single "906" piston, can you please tell me what the casting number is? Thx! Armando AJSERRANO at MSN dot COM
