-   -   Chain sound? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/547729-chain-sound.html)
OldTee 01-21-2011 06:47 AM
Fan belt too tight?
chiroracer 04-05-2011 09:53 AM
He ran it with no belt and same sound. Good luck !
tyro 04-07-2011 04:00 PM
Originally Posted by 4sd911 (Post 5757133)
I've removed the pressure feed tensioners and installed turbo style tensioners
I'm curious about the turbo style tensioner? Spring type? Have a part number handy?
Thanks,
4sd911 04-07-2011 06:08 PM
These Pelican Parts - Product Information: 930-105-053-00-M260 the last of the contained oil / spring type, some call them "turbo" because of the 930 part no.
El_Mecanico 02-26-2012 04:43 PM
Did you ever figure out the problem?
cmcfaul 02-26-2012 05:42 PM
I did. turns out all the head studs on the right side were lose. It's a head scratcher as to why but every head bolton the right was lose a 1/4 turn.
Torqued them all back up and runs like a champ again.
Chris
73 911 E
4sd911 02-26-2012 08:34 PM
Switching to the tensioners back to the "Turbo" type got rid of the "noise". I don't know if it was really a problem in the first place, or if the pressure fed tensioner's were bad or the different chains were just noisy. I suspect the pressure fed tensioner's apply more tension to the chains than the Turbo type. I do get a little chain noise at cold start up for about 30 seconds until the tensioner's even out, had that same issue with the pressure fed type before the rebuild.
cmcfaul 05-20-2013 01:47 PM
sorry, just realized I replied to the wrong thread.
