-   -   How to remove flywheel bolts? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/548270-how-remove-flywheel-bolts.html)
sc911s 06-15-2010 09:39 PM
Hi all,
please advise if the tool to remove the flywheel bolts has to come from Porsche or is it a standard 12 point torque drive socket that will do it?
and where would i purchase the correct tool in LA.
cheers
Flat6pac 06-16-2010 04:21 AM
Standard 12 point and its available auto stores.\
Bruce
cstreit 06-16-2010 07:20 AM
It's best do do this with the engine NOT on the stand. (rather on a jack or table) THe bolts heads are shallow and often locktited in. I hit them with a torch to help release any locktite and use an impact so I can push the tool into the bolt-head.
