Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by blue72s View Post
Why sequential?
Sequential shift linkage tends to be easier to route and fabricate.
Sequential gear boxes also offer speedy shifts with less misshifts.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-30-2010, 10:05 AM
120 HP/Liter is all I ask
The GT1 'box is actually upside down. Again not suitable for me.
Interesting, I am not surprised.
I'm curious why a 915 is not an option for you.
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche
Old 06-30-2010, 10:34 AM
A 915 will not handle the power/torque of a GT-3 engine for very long, even with pressurized oiling and a cooler.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-30-2010, 11:42 AM
gearhead
Interesting. I'd be interested in knowing more about the exact application.
Isn't one of the problems the Cup Cars have had is breaking axles when they lower the car too much because of the angle? If this car used a similar ride height, that 5" higher flange location might now not be such an issue and actually more of a benefit. Though maybe you've already measured this and checked the actual fit of a GT3 gearbox?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-30-2010, 12:44 PM
Also, could it be possible to easily adapt the cable shift linkage of a GT3 gearbox to mid engine location?
Old 06-30-2010, 02:02 PM
Yes but you're talking about RSR not Cup cars. However, the new RSR (2008 onwards) has a new gearbox - transverse type I believe - to lift the output shafts a little higher.
I would like to see the 2008 RSR manual. Anybody got one here?
Old 06-30-2010, 08:05 PM
johnman001's Avatar
This may be a stupid suggestion, but what about a trans out of a Cayman or a Cayman convertible (aka Boxter Spyder)?
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 06-30-2010, 08:15 PM
Similar ride height for street use? You've got to be kidding. How could the kerbs, ramps and things be overcome?
Old 06-30-2010, 08:21 PM
gearhead
You never said street use. I asked for more details on your exact configuration and application which you have declined to provide. I can't read your mind, so how am I supposed to know it's street use? I asked a question looking for more guidance from you and this is the response? You don't make it very easy to help you with this...
1974 914 Bumble Bee
2009 Outback XT
Old 07-01-2010, 06:12 AM
^ OK, sorry.
Old 07-01-2010, 06:27 AM
Doing a little homework, I am not so sure that the aluminum case 915 would not work with a few modifications, particularly in a street/occasional track application in a light car.
Reading Frere's book on the 911, he states that the 915 was designed for an input torque of 181 pound feet, but the original used a magnesium case. He states that Porsche increased this to 275 pound feet with oil cooling and presumably the later aluminum case and bearing mods. Frere also states the the 915 gearbox worked for the '74 Racing Turbo Carrera 2.14 liter which produced 400 pound feet of torque although this was with "some reinforcements" and "not without some problems".
My point is it seems that the 273 pound feet of a 3.6 GT3 engine should not be a huge issue for the 915 gear cluster, particularly if oil cooling, side plate reinforcement, an 8/31 R&P, and steel differential bearing plate with 930 bearing are used.
The weight of the car has to be factored in too, the lower the inertial loading the better.
Wevo has a product line to do all this, as well as a shifter kit to mount the 915 in a mid-engine. If Guard straight cut gears were used, the torque output would be increased much further for a racing only type modification, or for someone who loves gear whine.
Old 07-01-2010, 12:23 PM
Max Sluiter
Flieger's Avatar
I thought about that before. The inertial loading will be proportional to the acceleration. Therefore the gear stress will be less on a light car only if the acceleration is constant. If the thrust is constant, then the acceleration of a light car will be greater and the stress on the gearbox will be equal. Thrust is proportional to throttle, so basically you could not use full throttle if you wanted that to be true.
Old 07-01-2010, 04:50 PM
Makes sense.
I was thinking more along the lines of the initial stress during a clutch popping hard launch in first gear.
Old 07-01-2010, 05:28 PM
Originally Posted by YTNUKLR View Post
You can't flip the ring because it's hypoid, right?
Right. Negative hypoid does not work.
Old 07-01-2010, 06:50 PM
Is this for a 914 or something else?
Cayman.
Application: Street/occasional track.
Ride height: Similar to street 997 GT3.
Old 07-01-2010, 07:01 PM
Not a light car. About 2,800 lbs if I'm lucky.
Old 07-01-2010, 07:03 PM
Max Sluiter
Flieger's Avatar
So, Cayman gearboxes are not strong enough? There are 3.8 and Turbo conversion street cars, and there are a few being raced.
I would think it would be easier to make an adapter plate and flywheel than convert the engine to spin the other way.
Old 07-01-2010, 07:54 PM
OMG, no,... These have many issues and once you see one all apart, its soon quite obvious what these really are.
The G50 6-speed is FAR stronger, especially a late Cup or RSR version.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 07-02-2010, 12:14 AM
Max Sluiter
Flieger's Avatar
How about one of these?
Or maybe Audi would like to get rid of their old R10 boxes. That can handle 1,000 foot-pounds of torque or thereabouts from the 5.5 liter V10 turbodiesel.
Or there is the Carrera GT gearbox with the cool, low-inertia clutch.
What did 962s use?
Old 07-02-2010, 12:30 AM
gearhead
What did 962s use?
A 5spd evolution of the 930/935 4spd. Canepa might have one for sale. It's gonna cost more than a GT3 box.
Now that I know the application, I still think the inverted GT3 box is the way to go. It's been done already. It can be made to work.
1974 914 Bumble Bee
2009 Outback XT
Old 07-02-2010, 06:12 AM
