-   -   Valve Guide Removal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/552404-valve-guide-removal.html)
Daviboy 07-10-2010 02:50 AM
Valve Guide Removal
Hi guys got my shipment yesterday with all new valves, guides,seals and springs. I initially thought I could get away with using the valve guides but the amount of lateral play when I slid the new valves in was intolerable. So question is whats the best way of removing the old guides? I have read the section in Waynes book on this but just wondered if there is an alternative method.
Daviboy 07-11-2010 11:20 AM
No one have an alternate method?
rvanderpyl 07-11-2010 01:00 PM
Don't remember Waynes method, but the two I know of are:
1. Drill guides with a drill just a tiny bit small than the OD, pick the remaining out.
2. Take a bar sized to a slip fit of the inside of the guide, with a step milled in as a stop, place in freezer, Heat the heads with a torch, place bar into guide and knock out. This is the method we used to use on light aircraft engines. In a production shop we had a fixture that held all the cylinders of a row of torches, so they could all be heated at once, then they were rotated and there was a set of drivers in the freezer so you could do them all at once. The guy who did this job could replace a full set of 6 in about an hour, including removing, sizing and driving in, reaming and sizing the bores.
gearheadgreg 07-11-2010 04:21 PM
They make stepped drill bits to center on the hole in the guide, taking out most of the material to weaken it and allow it to be driven out much easier. Aircooled VW people have been using them forever.
Henry Schmidt 07-11-2010 05:10 PM
We tap the seal end of the guide with a 10mm x 1.50 tap and screw a 10mm bolt in about 15 mm deep.
The from the opposite end (seat side) you push on the bolt with a punch or a pilot tool attached to an air hammer.
No heat is required.
Hebster52 01-20-2012 02:46 AM
Thanks Henry! That's a great idea!
Been familiar with the stepped drill from the VW aircooled scene but this appears even easier. Dont have to worry that the drill brakes etc... ;)
porterdog 01-20-2012 05:36 AM
Wow, I'll say. Thanks for sharing.
Henry Schmidt 01-20-2012 09:58 AM
A picture's worth a 1000 words.
http://forums.pelicanparts.com/uploa...1327082265.jpg
http://forums.pelicanparts.com/uploa...1327082062.jpg
http://forums.pelicanparts.com/uploa...1327082077.jpg
http://forums.pelicanparts.com/uploa...1327082087.jpg
http://forums.pelicanparts.com/uploa...1327082124.jpg
http://forums.pelicanparts.com/uploa...1327082138.jpg
http://forums.pelicanparts.com/uploa...1327082151.jpg
http://forums.pelicanparts.com/uploa...1327082159.jpg
nocarrier 01-20-2012 10:12 AM
Is there a tool to set the correct depth when installing a new guide?
Also, what is the right amount of interference for the guide and the head? Shouldn't that be measured and the guides turned to fit the heads?
boyt911sc 01-30-2012 07:59 PM
How about a good show & tell for valve guides installation........
Henry,
That's supper nice of you to provide pictures and explanation for the valve guide removal. How about installation techniques and procedures for the valve guides? Pictures obviously would help us follow or understand your procedure. Thanks.
Tony
PrimeMvr 01-30-2012 10:30 PM
+1 on Henry's method. Used it yesterday and it worked slick! Thanks for sharing your expertise.
totle 01-31-2012 01:25 AM
Great writeup. Thanks Henry
Please also post installation pictures
crummasel 01-31-2012 01:37 PM
Henry, i am doing it the same way, but pushing the guides in opposite direction as the original repair manual recommends. Maybe just a detail but i would fear dirt or maybe widened lower ends of guides could additionally stress the holes.
But also as to my experience a good methode.
Greets Robert
Henry Schmidt 01-31-2012 04:32 PM
Greets Robert
Pushing the guide from the spring side to the seat side is a huge mistake.
If the guides have ever been replaced there is a good chance (90%) that the guide has a lip that helps the installer to install guides consistently.
If the pull that lip through the head you run the chance of splitting the guide boss on the inside of the port.
http://forums.pelicanparts.com/uploa...1328056328.jpg
http://forums.pelicanparts.com/uploa...1328056338.jpg
crummasel 01-31-2012 05:51 PM
Correct, Henry,
but among a lot of motorheads i have done (here in old europe) i have never seen this case and to make sure i am doing measurements before.
In such a case i would for sure do it reversely like you, but as said, it usually did not come up so far.
Replacement guides you get over here (unless you make your own) have a plain, straight outer diameter without any lip.
Greets,
Robert
Henry Schmidt 01-31-2012 06:20 PM
Originally Posted by crummasel (Post 6529479)
Correct, Henry,
Greets,
Robert
Robert, on your heads you can do as you please. It is my goal by posting on these threads to assist the DIY builders to succeed on their project. That is why I will warn all those doing your own heads to follow my suggestion or use a core drill or whatever method you choose just don't push the guide towards the seat side, period!!!!! It is way to risky.
crummasel 02-01-2012 02:08 AM
Henry,
if the cracks shown on your photo were caused by pulling the guide towards the spring side it would prove what i said. But more likely it shows a cracked lower guide bore area caused by an oversized seizing guide being pushed in from the spring side (maybe also with wrong methods), so not an example for a removal of a guide towards the seat side.
However, i fully agreed to your methode, just a small comment to it (by the way with the same intention as yours to make DIY - builders more successful) so no reason to shout. ;-)
I will not comment any more, seems we do not have as much experience on Porsches in Germany as you have in CA. ;-)
Henry Schmidt 02-01-2012 04:43 AM
Originally Posted by crummasel (Post 6530002)
Henry,
The cracks were caused by pushing the old guide through the head (using a core drill), towards the seat side. All six heads suffered the same damage.
They were sent to me to repair after the owner kludged them up. We suggested he just replace the heads.
As for your "I'm German so I must know" comment: I would think you don't have to be a Hawaiian to open a coconut, any monkey can do it.SmileWavy
304065 02-01-2012 06:53 AM
Half of all aircooled Porsches EVER sold went to California.
Half of those went to Southern California.
I think it highly likely that there are a few of Henry Schmidt's engines in Europe given the Euro exchange-- lots of great California cars are making their way back to Germany. :)
88911coupe 02-01-2012 07:08 AM
This was one aspect of my rebuild I was not even going to try myself. I just was too nervous to mess something up badly. This is where someone like Henry is extremely valuable. I actually had all this work done by Competition Engineering and it really was not too expensive in the whole scheme of things.
Henry Schmidt 02-01-2012 07:38 AM
Quite frankly, Competition Engineering is a great choice. I like Walt and he does great work.
MBEngineering 02-02-2012 01:33 AM
HI
As Henry has noted, do NOT take it that the guides are strait no mater where you live, as there are shouldered guides supplied in the UK, so check what you are working with
http://forums.pelicanparts.com/uploa...1328174992.jpg
http://forums.pelicanparts.com/uploa...1328175017.jpg
UK supplied guides, and to quote Henry if I may, "never assume any thing"
regards mike
crummasel 02-03-2012 05:29 PM
Absolutely, i would'nt doubt that basically while not knowing if to that extent. ;-)
Anyway it has just been an ironic replica on the slightly high and mighty attitude, just kidding.
A very long time ago a machine shop managed to crack one of my first Porsche motorheads by pushing the old guides to the valve side, probably caused by trying to push the slightly widened lower area of the guide and the charred dirt around through the bore.
After that i have "developed" my own methode (without knowing any forum) to do it and it was nice to see that it is exactly the same like Henry's, just in the other direction.
Good thing with this methode is that the old guide is not going to get compressed but streched. I made a huge amount of heads this way without any issue.
But for sure not by far as many as Henry. ;-)
Still trying intellectually to capture the monkey and coconut story...:confused::D
@mike
clear, but these ones you can identify and messure. Anyway a good strategy to messure and to think prior to applying force... ;-)
Dick Shift 03-26-2012 06:30 PM
Just my two cent's
I heat the heads to 350 before doing the above. As Porsche recommends. That insures the thin casting around the valve guide boss in the intake ports will not crack or chip off. I learned this the hard way. You don't need to. Aloha, DS
john walker's workshop 03-26-2012 07:22 PM
of the hundreds of heads i've done, i never heated one. with proper technique, the guides come right out. i used to do vw guides with the tap and bolt, but on 911s i step drill and air hammer them out with a light trigger finger. on the air hammer bit, it's a good idea to taper the step so it doesn't catch the guide bore as you run the guide out. on installation, spray some WD or some other similar product in the bore and on the guide before installing. makes them go in smoothly. always mic the old guides and the new ones so you don't inadvertently run in an oversize by mistake.
Dick Shift 03-26-2012 08:33 PM
And,
Put the new valve guides in the freezer the night before. With a little anti seize on the new guides before installing...... in like butter.
always mic the old guides and the new ones so you don't inadvertently run in an oversize by mistake. Good idea!
aquazulu2 01-05-2014 11:16 AM
I knew if I looked long enough I would find the DIY answer to valve guide removal and recognize the pros when I saw them. Thanks for posting this helpful thread. The end of the discussion got a little heated and got thrown in the freezer a few times, which may have taken away a little from the final solution; installation of the guides. but great technique! I believe. I will try the old tap, bolt and drive out method, as agent smart would say.. SmileWavy Great idea. Printing as an addendum to my bentley manual..
rtroy 07-23-2018 05:30 PM
(The bolding emphasis was added.)
This is a great question that everyone has ignored, and is, in fact, the reason I've come here to look around today... I would really appreciate if some of the old timers spoke up and shared about this!
Some many years ago (late 1980s), I did a number of engines worth of valve guides and seats and had some good advice from others. (I was an apprentice of David Brown at Weissach Engineering, Colorado Springs, now long gone, unfortunately.) I have a mill and a lathe and I got some numbers from him and his machinist of the form:
"For steel seats in an AL head, your theoretical best interference fit is X for every Y bore. Calculate your intake seat fit with Z% more crush, but don't go beyond W% or you risk cracking the head. Bronze guides in an AL head should have a crush of X for every V of bore, but there's always a minimum of L, and intakes should always have J more crush. If it's a silicon bronze guide, alter this by K."
And I did guides and seats like this for some 3 years or so and it all worked fine. It's worth noting that I used the rather unorthodox strategy of installing (especially valve seats) by using a quart thermos of nitrogen, about 1/2 full, and then dropped the seats / guides in to a room-temp head and it all went in without a problem. I used the "stretch em out" threaded spring end, drift through to the bolt-in-threads from seat side strategy for removal, and used the old guide ID as a BIG help on determining where the existing guide bore may be at since the bores in the head can be hard to measure accurately with a bore gauge... If you have the old guide, and can get a feel for how hard it is to remove, you can build a sense for how relatively tight or lose it is in the head and thereby have a good feel for the current interference fit.
But doing heads was a pain in the but, so I farmed the work out starting around 1990 and now, starting around April this year, that shop isn't doing them any more, and I've lost track of my notes. ... About two weeks ago I literally bought over a ton of Porsche parts and I now have added four engines to rebuild on my already extant queue of at least four I was already doing, so that's a LOT of head work, and now's the time to figure this out! What's worse, some of these heads have the guides already removed so, no help there!
Any input?
ed mayo 07-23-2018 09:18 PM
All the guide fit numbers you want are in the 'little spec books'
