Walt Fricke's Avatar
I just switched from a carbureted 2.8 race motor to EFI and ITB. The throttle response was amazing. Good for a couple of seconds on the track. But track tuning is a lot simpler than street tuning, as you really don't care about part throttle or idle.
A mag cased 2.7 is not, however, the engine I'd want to fuss around with hot rodding. Longevity compromised with stock power as it is. CIS is a pretty nice street system. Its complexity is at least easier to understand to some of us than a computer controlled system. It can be made to run just fine.
Walt
Old 10-29-2010, 08:52 PM
safe's Avatar
EFI is sweet with endless tunability, but I think its a lot easier than carb and CIS. My belief is that initial tuning of an EFI system on a rolling road by a professional is mandatory.
A good tuner will have the system running at 99% in 4-6 hours.
Back to the mag case CIS to carb with e-cams. I just want a sweet running street engine with good throttle response and a bit more power than its original 165-175hp.
Magnus
Old 10-30-2010, 01:49 AM
red 2.7's Avatar
carbs?
I have a very sweet running mag case 2.7 1977 with PMO 40's e cams barry hershon recurved dizzy ssi's and m&k 2 in 2 out. MSD 6al. Idles beautifully and pulls strong up to the redline and beyond if I let it. I have a 6.5k limiter. I could not recommend it mor e it's super. I only had to change idle jets from 55's to 60's to remove a slight flat spot at transition. It's a little loud but i love it. I had Webers before the PMO's and they were sold for $1500 and the new PMO's cost 3K I think. My pro Porsche mechanic's butt dyno estimates 200 to 210 horses. good luck with your project.
wally , Montreal
Wally in Montreal, Canada
My age 50 something,P- Car's age 30 something 2.7 911S PMO 40's , E cams, RS pistons/cylinders, MSD6AL, Pertronix, SSI's, M+K 2 in 2 out. Perfect studs (whew!)
Old 11-02-2010, 12:03 PM
safe's Avatar
wally , Montreal
What pistons do you have?
Magnus
Old 11-02-2010, 12:11 PM
al lkosmal's Avatar
Here is my EFI ITB setup......
My Triumph Speed Triple project update
RGruppe #669
http://www.x-faktory.com/
Old 11-06-2010, 07:31 PM
JmuRiz's Avatar
wally , Montreal
Sorry to bring up an old post, but I'm in the process of getting parts to convert to carbs as well:
When you all do an MSD 6al ignition do you also convert the dizzy to remove the points?
Thanks,
Nathan
PS: al lkosmal - your ITB setup sure looks cool, I'll probably check into something like that at some point, just no all-inclusive kits for us newbie EFI ITB guys. If yours ends up like that I'd be all over it.
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 01-05-2011, 02:08 PM
You can use the points with the MSD. I haven't done a conversion to no points. I like the simplicity and reliability of points.
-Andy
Old 01-05-2011, 06:59 PM
