-   -   Rebuilt Tensioners (http://forums.pelicanparts.com/911-engine-rebuilding-forum/553687-rebuilt-tensioners.html)
Daviboy 07-17-2010 06:34 AM
Rebuilt Tensioners
I recived my re-build kits yesterday so this morning decided to rebuild the tensioners. I was frankly amazed at the condition of the 28 year old internals only a little shaving off the outer oil piston o-ring. Anyway got them apart and cleaned up nicely. The only tricky part is getting the small c ring back in to hold down the lower piston tricky but doable. I am not going with oil fed as I cant afford them right now plus the originals lasted 28 years so I am sure I can get another 10 at least from the rebuild although going to put the savers on just in case.
Flat6pac 07-17-2010 01:19 PM
Put the guards on them and you ll be good to go. Remember to leave some room for flex, thats what the spacer is for....
Bruce
Daviboy 07-18-2010 10:08 AM
Bruce thats what I meant by savers... I reckon Porsche knew what they were doing when they designed them and if rebuilt properly should be serviceable for a long time...
Flat6pac 07-18-2010 06:43 PM
I believe the collars are actually an after market part but can save the engine...
Bruce
