Intermediate shaft noise question
It looks like the intermediate shaft is the source of my noise. Looks like the motor has to come out again :mad: I kick myself for not splitting the cases but at 29k miles who else would have? Some mechanics say don't worry about it. To me it sounds worry some. I will have the oil checked for metal just in case. Is this a time bomb or just annoying?
1996 993 with 29k miles. |
JMHO, but at 29K, its rare to have an intermediate shaft problem. A real sharp, experienced mechanic can spot this with a stethoscope.
These things do occur, albeit rarely, so you'll need to open everything up to have a look. |
Please excuse my ignorance, but for the benefit of us uninformed masses, what does this sound like?
Hi John,
As you might imagine, such things are virtually impossible to describe in writing since many engine noises vary by frequency, pitch & amplitude. Intermediate shaft noise sometimes makes a light knocking or rumbling sound that differs from bearing noises or wrist pin knocks. Its FAR easier for one to listen to various engine sounds under the tutelage of an experienced person to learn and discern the differences. |
Do you know what typically makes noises when it is suspected that the intermediate shaft is causing the noise(s). Is it bearing related? Does the shaft walk axially and tap on something? The reason I ask is that I had a noise that I could not identify in one of my spare engines. I have yet to take it apart. I was assuming it was a quiet noisy rod bearing but didn't really act like it was. One of these days, the noisy engine case will be split and I (hopefully) will be able to identify the source of the noise. |
Intermediate shaft noises stem mainly from worn bearings and worn (or mismatched) gears. Chain sprockets rarely make discernable noise, even when the teeth show some wear.
In some situations, excess end play (thrust) makes noise and thats caused by worn thrust bearings or an engine case that wasn't machined properly. You'll know when you have it all apart. :) :) While I don't recommend them for street cars, there are straight-cut intermediate shaft gears that eliminate thrust wear, however they do make a racket. |
I just came from the dealer. The tech feels it is coming from the intermediate shaft area. He is also hearing the noise in the bell housing. He felt the noise was traveling down the crank and that is why he also hears it in the bell housing area.
After taking him for a ride and having him listen to the noise inside the car he was not so sure it was not coming from the trans and traveling down to the intermediate shaft area. I don't understand how that can be since when the clutch is pushed in and the car stopped the trans does not turn. When I go for a long ride the noise seemed to be less. Couple more pieces to the puzzle. When I got the car the tune was so bad it barley idled and lumped around like a V8 chevy with cams at 600RPM. Did that hurt something? I also know the trans main shaft is bent. I have a call into Jerry Woods. He has LOTS of experence so I hope he can provide some insight. His shop is not that far away. |
How common is this problem? I have read some engine rebuild posts where people suggest that once your engine hits 100k miles, that is "not uncommon". However, I have also read a couple of high mileage posts where people put over 200k miles on their SCs or Carreras with nary an issue, which would suggest that the issue is not common. So what causes the problem repeated high reving, or poor lubrication???
I have only had my car for a month (got it at 98k miles) and will be doing the second oil change shortly at 100k miles, and will be doing an oil analysis. If copper shows high, it will give me some sleepless nights. :( I'll be wondering the same thing, "how long can I safely run it ?" |
There are MANY factors that affect intermediate shaft bearing wear that include, but not limited to: oil change frequency, type of oil, and valve spring pressures. I don't believe that high revs affects this unless one has stiff racing valve springs. These are not all the same since seat pressures vary among them and some are much worse than others. |
Don't forget to check the Pilot bearing too.
Because it is in the end of the crank, even in Neutral, clutch out, stopped, and idling this can put out some noise. Bob |
MotorMeister.ClassAction@hotmail.com
looking for all individuals who have bin victims of FRAUD!! please email Name/ contact info.. and if you want to be contacted or not!!!! car model/ work done(OR NOT DONE)date of work. ALL documentation pertaining to your situation!!! any information will help!!! all participants of ClassAction (who are in the right!!) can be compensated please spread the word!! COPY AND PASTE THIS TO OTHER FORUMS!! the more participants of this suit.. the more likely MotorMeisters will finally be held accountable. Thank you!! ON FACEBOOK!! SEARCH-- MotorMeister ClassAction Welcome to Facebook |
With car stopped and clutch pedal disengaged (out) and engine idling, there is no relative movement between the mainshaft and flywheel. It is not likely pilot bearing can generate any noise especially if it is not moving.
Matt is right...sorry...you need the clutch disengaged and the car in gear to make the bearing do it's work.
In that way the throw out bearing is also in play. Pilot bearings are stupid little cheap things....but can make all sorts of noise when bad. The easiest way to extract one from the crank is to pack the hole with grease....then drive in a rod of the correct size to go into the bearing. The hydraulic effect will pop out the old bearing like a charm. Have fun. Bob |
Just out of curiosity did this noise just show up or has it been getting louder with time and mileage? Are you running a stock flywheel or is it an aftermarket unit?
The noise was present when I bought the car. I have not put many miles (3k maybe) on the car. The noise gets louder at times. I don't think it has changed much since I got the car but it's hard to say for sure. |
K24,
where do you live? If you're in the Houston area, I wouldn't mind coming by to help a little if you decide to drop the engine yourself. |
Just had a thought.
Do you have one of those long probe stethoscopes? Parts suppliers like Pep Boys etc sell them fairly cheap. With that tool you might be able to determine whether the sound is coming from the front or back of the engine. Bob |
i have heard tremendous gear rattle travel all the way through the engine because of a light weight flywheel install. this was on a 996 TT. and it was a Porsche motorsports flywheel.
I cut open the oil filter on the motor and spread out the element. I found no metal in it. I also poured the oil left in the bottom of the filter into a glass of water and saw no metal there.
I just came back from 3 track days and the noise remains the same. sometimes lounder than others. Oddly when coming off the track it is the quietest (other than when its cold). It is the loudest when the motor just comes uo to temp as per the oil gauge. I have a oil sample I am sending off to blackstone to be checked. |
You said the transmission main shaft was bent? How did that happen?
Mark |
You said the transmission main shaft was bent in post number 8. How did that happen?
Mark |
The oil analysis did not reveal anything strange. Based on all of my home work I can safely chalk it up to noisy intermediate gears that are not life threatening. Thanks for all of your feed back and help.
