-   -   3.2 engine rebuild advice. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/555338-3-2-engine-rebuild-advice.html)
CaptainCalf 09-15-2010 12:35 PM
Could it be that the carbs need rejetting to match the new cam profiles? Did they run and air/fuel ratio on the dyno?
safe 09-15-2010 12:55 PM
No carbs, EFI system. The power curves you see is after dyno tuning.
