head gaskets?
So why is the head gasket seal kit more $ for my 76 turbo? Fewer need it? Would any other kits just work on my engine?
Its a mix between a 2.7 and a 3.0
3.0 bottom end gasket set 3.0 top end gasket set 6 extra cis intake manifold gaskets main seal behind flywheel for a 2.7 depending on your exhaust, on a 76 there is a triangular on the right and leftback by the turbo pipe and there is square gasket off the thermal replacements to the heat box. There is a gasket for the turbo to sit on and two to the muffler later model exhaust is the prefered way to go, more power, less heat You can pretty much build with this info Bruce |
