pete-stevers's Avatar
what is acceptable oil pressure
I am wondering what is acceptable oil pressure on and older 3.0 engine?
What is the min pressures an engine should run at idle warm?
Old 01-10-2010, 07:18 PM
The owners manual says it's acceptable for the oil pressure light to be on at idle when hot. I've seen as low as 5 psi at idle with the engine very hot (240 degrees). Rule of thumb is 10 psi per 1000 RPM. For example: 20 PSI at 2k, 30 PSI at 3k, etc.
-Andy
Old 01-10-2010, 09:24 PM
If you have the 3.0 in an early car, pre 78 the thing you have to do is match the sending units to the guage both the oil pressure and the temp sending units have to be replaced
Bruce
Old 01-11-2010, 06:21 AM
T77911S's Avatar
-Andy
i thought that was the rule for the early cars. when they went to the 2.7(?) they increased the pressure side of the pump and reduced the scavange, acording to bruce andersons book. my 2.7 is almost 60 psi at 3k, and hot. did they change the pumps back for the 3.0's?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-11-2010, 10:42 AM
They did not change the pumps back for the SC. I thought those numbers were for all 911's up to the 3.2 Carrera. 964's may be different. The numbers I quoted are minimums. My car shows 60 PSI at 40 when hot. I think the original question was what is the minimum acceptable oil pressure.
Old 01-11-2010, 10:53 AM
Oil Pressure not above 4 Bar?
Hello, I have an SC with 3.0. The engine was recently rebuilt by a shop that is well regarded on this forum and the Early S Registry. I am still breaking in at about 1,000 miles and just had the oil changed again and tune-up/valve adjustment. The engine is running very well except the oil pressure has me a little stumped. When the engine is warm at 80 C the oil pressure is right at 4 bar at 4,000 rpm, which willl drop only slightly to about 3.7 bar when it heats up to between 95-100 C. However it virtually never goes above 4 bar, especially once it's warm between 80-100 C, it only ranges between about 3.5 bar at 3,000 rpm to 4 bar at 4,200 thru 5,500 rpm. I have not exceeded 5,500 rpm yet, but will soon.
So it seems to have good to factory spec pressure up to 4 bar, but I expected more pressure in the 5,000+ rpm range as with other 911s that I have owned.
Any insights? The car has a front loop cooler, and the engine rebuild included a full bottom end with the original 3.0 oil pump. I use Valvoline VR1 20w-50, and live in "Hot"lanta (at least this summer).
Thanks for your thoughts.
Old 07-29-2010, 04:44 PM
Best to confirm with a mechanical guage first.. The electric guages are often wrong. Low oil pressure after a rebuild can be caused by excessive clearances either in the bearings or pump. This would likely show up as VERY low pressures at idle and low RPMs, not normal low RPM press then low at higher speed.. You may have a weak pressure relief spring (there are 2). It would allow the pressure to rise with RPMs normally until it reached a certain pressure when it opens and pressure goes no higher
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 07-31-2010, 06:45 PM
