-   -   Spark Plugs for Twin Plug (http://forums.pelicanparts.com/911-engine-rebuilding-forum/557154-spark-plugs-twin-plug.html)
chris_seven 08-05-2010 07:19 AM
I am trying to decide which plugs to use for a Twin Plug 3.0 litre with 10.5:1 pistons and GE60 cams.
I think that the plugs in standard engines changed from a Non-projected to projected type in Mid 1978 and I am a bit concerend about clearance.
I am thinking of NGK B8EVG or B9EVG ofr the 14mm plug and using a D8 or D9EVX for the second plug.
I am sure that there is plenty of experience around and there may be a better choice.
The car will be used on endurance rallies in East Africa.
Henry Schmidt 08-05-2010 07:43 AM
NGK BKR 6 EKUB
Bosch FGR 6 KQE
Adjust heat range (5,6,7,8) to suit intake and altitude
chris_seven 08-05-2010 10:08 AM
Plugs
Henry,
Thank you :)
lindy 911 08-05-2010 01:15 PM
I have the same motor and run the NGKs that Henry lists with no issues.
Lindy
Shoepop 08-07-2010 08:25 PM
Originally Posted by Henry Schmidt (Post 5490944)
NGK BKR 6 EKUB
Bosch FGR 6 KQE
Henry, could you please explain why one would have to adjust heat range for altitude? I'm going to guess higher the richer so you need a hotter plug on cars with say carbs that don't compensate as well as a modern engine fuel management system?
