-   -   article discussion (http://forums.pelicanparts.com/911-engine-rebuilding-forum/558000-article-discussion.html)
gova 08-10-2010 12:52 AM
article discussion
In pelicanparts use hardwood dowel to drive the wrist pins out.you don't want to put a heck of allot of cross load on the connecting rods so don't spank them too hard.
__________________________________________
Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean*Groups* seo specialist
Daviboy 08-10-2010 02:41 AM
Conn rods are fairly tough if you need a lot of force to drive out wrist pins there is something wrong stop. I used the handle end of a screwdriver and mine came pretty easily...
Eagledriver 08-10-2010 09:31 PM
Heat the head of the piston with a propane torch. The pins will then slip right out.
-Andy
