-   -   Porsche RSR MFI regolation (http://forums.pelicanparts.com/911-engine-rebuilding-forum/558705-porsche-rsr-mfi-regolation.html)
cyber2213 08-13-2010 02:05 PM
HI...
i have a problem to set MFI whith rsr sprint cams and HighButterfly ...
explain:
how i must set MFI ??
40° after tbc 4 cilinder??
or 14° after delivery end of 1 cilinder?
many thanks...
:confused:
cyber2213 08-14-2010 03:23 AM
PLS..Help!
racing97 08-14-2010 07:57 AM
14 btdc overlap one which is tdc 4. set it right between the Z and the advance marks.
regards
cyber2213 08-14-2010 08:04 AM
oooo MANY >THANKS!!!!!!!!
set MFI at 14° BTDC 4CYL. ( between Z1 and FE mark) correcly??
racing97 08-14-2010 05:17 PM
Yes that is correct.
regards
cyber2213 08-27-2010 08:08 AM
Then ....
I set the MFI at 15 ° BTCD 4 cyl ...
As a result I had an enrichment at 4500rpm
Someone knows the difference there is in regulating MFIs in a different position from FE??
PLS Help
racing97 08-27-2010 08:51 AM
I don't understand exactly what your statement means " I had and enrichment at 4500 RPM" Really all this timing is intended to provide fuel just slightly before the inlet valve, which opens slightly before TDC (where you have set the pump) and cease fuel delivery before the inlet closes. A mechanical injection system provides fuel delivery as a square of RPM not based on a charge volume bases. This being said it will always be off somewhere, when these cars were being raced and you if dynoed them it was always rich at the top and stoichometric at peak torque or vise versa. I believe the best fuel curve BSFC wise was a 2.8 factory racing pump and the associated round cam, more often than not guys would shape the cams by hand to get the curve right.
cyber2213 08-27-2010 09:41 AM
i've a follows @4500rpm
A/F result
1000rpm 10.2
2000rpm 10.8
3000rpm 11
4000rpm <10
4500rpm <10
5000rpm 11.8
6000rpm 12.5
7000rpm 13.5
8000rpm 15
if septum, the MFI at 40 ° after TCD 4 cylinder what changes?
at this time is set 14 ° before TCD 4 cylindre
HELP!pls
Flieger 08-27-2010 10:36 AM
If you do not like the 14* setting, why not try the FE mark and see if you like it better?
cyber2213 08-27-2010 10:39 AM
ok..i try but...Does anyone know the difference in delaying or anticipating the MFI??
cyber2213 08-28-2010 07:02 AM
if you adjust the phased MFI of 360 °????
What happens??
