-   -   CIS gasket (http://forums.pelicanparts.com/911-engine-rebuilding-forum/560893-cis-gasket.html)
millhaus 08-26-2010 06:16 AM
CIS gasket
I am trying to replace the CIS fuel distribution gasket on my 1980 930. It is #21 in this photo.
http://forums.pelicanparts.com/uploa...1282828414.gif
There are several screws holding the two halves together that have springs on them. Currently I can tighten and loosen them with my fingers. When I take these apart to replace the gasket how do I re-tighten them? The manual says tighten to the block then back off one turn. Does this mean compress the spring until it is tight then back off one turn? As I mentioned mine are currently not this tight so I am not sure what they mean.
http://forums.pelicanparts.com/uploa...1282828573.gif
Daviboy 08-26-2010 08:55 PM
Do exactly as it says tighten down but not excessively then back off one turn. Done this with my 82 with CIS and never had an issue.
gombault 08-27-2010 10:42 PM
jj
