-   -   How do you get your headers back to shiny? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/563105-how-do-you-get-your-headers-back-shiny.html)
Tippy 09-07-2010 04:27 PM
My engine leaked really bad onto some places on my headers and baked on the oil but I have gotten rid of that with some not so Earth-friendly chemicals (pottassium and sodium hydroxides).
But, how do you get the stainless steel back to shiny using chemicals?
Is it caustic you use, or acids, or just plain ol' solvents? I would assume heat would be in order too.
My thinking was probably a mixture of either a caustic or an acid using heat for a nice long dip.
Whats the trick? Hand rubbing with a scothbrite and mild acids is not going as fast as I like but is givng me desired luster.
BeemerMike 09-07-2010 04:38 PM
My understanding is you don't try. The SS headers/HEs will discolor from the heat of engine operation, and the only way to avoid it is to not drive the car. My suggestion is to learn to like the color.
Tippy 09-07-2010 04:41 PM
No way, I do not like milky, brown on my headers. :)
tom1394racing 09-07-2010 05:02 PM
Tippy
Remove them and have them soda blasted.
Tippy 09-07-2010 05:21 PM
Originally Posted by tom1394racing (Post 5548268)
Tippy
Thought about it but didn't think it would be worth the cost.
BeemerMike 09-07-2010 06:22 PM
Well, all I can say is good luck. I have a garage full of motorcycles with single-wall SS exhaust systems. The ones with bare SS (the Ducatis) are both the dull, medium brown color. The ones with chrome-plated SS (the BMWs) have a "blued" look. Harley-Davidson and the Japanese bike makers avoid the blue discoloration by using double-wall tubing for the exhaust headers. I suppose you could have a set of double-wall SS headers made for your 911 . . . :)
Tippy 09-07-2010 06:28 PM
I know what causes the discoloration, I am simply trying to figure out the easiest and cheapest way to get them back to gleaming without a ton of elbow grease.
I am rebuilding the engine and want the headers to look nice.
BeemerMike 09-07-2010 07:00 PM
Tippy, I don't want to get into an endless back-and-forth on this, but if you know what causes the SS discoloration, then you know that what you want to do cannot be done (i.e., having shiny SS headers on an operating 911). Even if you found a way to get your headers back to "shiny silver" on your rebuild, as soon as you start the engine and drive the car for awhile, the SS will return to the dull medium brown color. It is not caused by the oil leaking on the headers (although that certainly makes it more messy), it is just the inherent nature of the SS. Sorry.
bavaria911 09-07-2010 07:27 PM
Tippy,
Please post your method to the board. If you solve the change in apperience of the SSI's, while under daily usage -- we'd love to know the secret.
Bavaria911
Plays with cars 09-07-2010 08:01 PM
I bought a bottle of stainless steel BBQ cleaner at Lowe's hardware that was supposed to clean SS discoloration. Didn't think it would work, but was hopeful just in case. Well surprise surprise, it worked, and with very little elbow grease. Even worked on my SS stove top.
Now granted BBQs and stove tops are operating at lower temps than your exhaust system, but this stuff took the heat discoloration out of the SS on them quite easily. Might be worth a trip to the hardware store to pick some up and give it a try.
Tippy 09-07-2010 08:06 PM
Funny you say that, I just bought Zep BBQ cleaner today and tried it. That stuff has the pottassium hydroxides in them.
It did not do too well for me.
That's when I got out the Easy-Off (sodium hydroxide) but it too just couldn't get the metal shiny again.
The best thing so far has been Bar Keepers Friend, scothbrite, and elbow grease.
K24madness 09-07-2010 11:58 PM
I hated it to. I had them ceramic coated black. Always looks good now.
jpnovak 09-08-2010 07:35 AM
The caustic materials (sodium or potassium hydroxide) materials will remove the oil and other carbon materials from the SS. However, it will also react and pit the stainless. Usually this is in the form of creating iron and nickel hydroxide materials that then quickly oxidize to rust. The gray appearance is most likely a mixture of the SS ingredient oxide materials.
The only way to remove this is to mechanically abrade the surface. Take your pick. Sanding, grinding, blasting... Either way, the surface is pitted. You can restore some of the luster by sanding progressively from coarse to fine grit and then polish as necessary.
All of the SS treatments are just fine polishing compounds. They lightly remove the surface oxide/nitride coatings while using the elbow grease. Mark said it best, The headers are subject to much higher temperatures and thus the depth of the oxide/nitride coatings is significant.
Of course, the first few times you drive the car they will turn that brownish(or maybe bluish) color indicative of the reaction of the metals with the oxygen and nitrogen in the air. There is no way to prevent this except for dual layer designs which insulate the outside.
Tippy 09-08-2010 08:40 AM
Great post.
I feel there has to be a caustic or acid that will attack/remove the oxide of the SS and leave a nice, lustery surface, no?
I figured with guys like Weiner and Schmidt, they must do something with the headers of customers cars to make them nice looking (for a short time of course). It must just be the mechanical sanding/polishing method.
My wife's Mother is a chemist, I gonna ask her and report back if I can find out anything worth doing.
Flieger 09-08-2010 10:24 AM
I thought the blueing was from a change in the crystal structure/temper of the steel due to the heating and cooling cycles from the exhaust.
304065 09-08-2010 10:45 AM
Jet-hot coating.
tom1394racing 09-08-2010 12:11 PM
John's right...I jet hot coated the headers, muffler and muffler straps on my RSR four years ago and they still look fresh.
Tippy 09-08-2010 07:46 PM
Nice!
Originally Posted by 304065 (Post 5549563)
Jet-hot coating.
Didn't want to go that route, just want to make them look nice again. After awhile it wont matter again to me. I just didn't want ugly headers on a fresh rebuild.
I bet those look sweet!
azasadny 09-15-2010 12:01 PM
I use Krud Kutter and 00 steel wool, followed by 0000 steel wool...
HFR_Racer 09-17-2010 02:47 PM
Plus one on the crub cutter..
I use a 3" dia. Scotchbrite type pad that is 1 inch thick that you can purchase at Sears in the tools department. The pad has an integrated drive arbor so you can use several tools to drive it.
http://forums.pelicanparts.com/uploa...1284759900.jpg
I high temp paint my stainless headers though. I plan to wrap them this winter.
