My friends call me Phish
Anyone know how many bolts, nuts and washers are on a engine build?
I want to replace all my bolts nuts and washers for my engine build and I was hoping someone would know the quantity/size of the hardware used, so I can just place an order with Grainger. If not, better start counting. 1, 2, 3, 4.....
Pelican's 'Case Hardware Super Kit' is pretty comprehensive. It's not everything, but close, including a lot of very specialized pieces. There's a list of what all it contains if you want to use it as a guide:
Pelican Parts - Product Information: PEL-REBKT-06 I didn't do this, but in retrospect it might have made sense. Mike
Michael Caterino Clemson, SC 1970 tangerine (=Tiger Orange) 'T' targa restoration: mk911.blogspot.com |
Less brakes, more gas!
I used that kit. It is very nice and covers almost everything that I could possibly have wanted. Very worth it. I did research prior to buying it and if you just want to have general HW for the engine then that's one thing, but for a full split the case rebuild this kit works well.
-Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
I too liked the kit I used from our host.
I only have one complaint about the kit. I did not like the quality of the 8mm aluminum flat washers. Much too soft. The aluminum flat washers included with valve cover gasket sets are much more durable than the ones included in the engine rebuild hardware kit. I ended up using different aluminum flat washers.
John Flesburg 2016 981 Boxster S.................| 1983 911 Turbo - (White) 1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver) 1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?) 1971 914 (TBD)..................... | |
