Twin Plug Distributor
As I am considering twin-plug ignition on my spare hot-rod 3.0L SC engine with 46 PMOs I wonder what the 'best' twin plug dist. would be to purchase in terms of accuracy/ tolerances/ overall building quality/ reliability?
JB Racing's dist. seems to have a good reputation and are used extensively also here in Europe, so this might be the 'best' way to go?
I plan to run it with a twin coil MSD.
Any suggestions or personal experiences are appreciated!
Many thanks,
Christian
Old 10-07-2010, 09:58 AM
Many thanks,
Christian
Thats an excellent choice.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-07-2010, 11:03 AM
Constitutional Liberal
Turbo_pro's Avatar
I use the Supertec / Rennwerks distributor with very good results.
I chose the Supertec option because I wanted a distributor that had an old school aesthetics. I really hate use billet aluminum parts on my 911s and turbo engines.
Billet stuff looks great on my hot rods but just doesn't seem right on a Porsche.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 10-07-2010, 11:18 AM
Jim,
Got your point regarding the aesthetics.
Does the Rennwerks from Aaron/ Supertec contains internal ignition triggering with an adjustable advance curve? What sort of bearings/ bushings and internal shaft seals is used?
Do you use it with a MSD? Is the price comparable to the JBR?
Thanks,
Christian
Old 10-07-2010, 11:51 AM
Saw this at the early registry today:
Porsche 911 RSR BOSCH Twin-Plug Distributor Reproduction Made in Germany
Old 10-07-2010, 12:16 PM
m1franck's Avatar
If you are not concerned with an "original" looking distributor filling the hole in the engine case, wouldn't an Electromotive crank trigger setup be a better way to go? Seems like at under $1,400 it would cost less than these 12 plug wire distributors & would certainly be a cleaner install since you don't need 2 CDI or MSD boxes. Aren't they also much more tunable that a traditional distributor?
What's the downside, other than not being original looking?
Old 10-07-2010, 02:58 PM
AlfonsoR's Avatar
Ignition accuracy is the key to making the most power, right.
Old 10-07-2010, 08:31 PM
Turbo_pro's Avatar
Jim,
Thanks,
Christian
The distributors are built (curved) to your engines specifications.
The foundation for the distributor, hence the triggering mechanism is from a stock 911SC or 930 turbo. I think the early distributors are actually based on a BMW distributor.
The Rennwerks/Supertec distributor uses shaft bushings like the stock SC but adds a sealed high speed ball bearing directly under the rotor for additional high speed stability (much like the Marelli and Bosch twin plug distributors).
I use the MSD 6AL as recommended by Henry. 1 MSD box and 2 high vibration Blaster II coils.
I believe the Rennwerks dist. is slightly more expensive.
Jim
― Thomas Sowell
Old 10-08-2010, 07:04 AM
Thanks Jim.
Don't you need to run twin MSD boxes (6AL) on a twin plug setup?
Best,
Christian
Old 10-08-2010, 08:38 AM
Carrerax's Avatar
After talking to several people including Steve W, I decided on the one from JB Racing. IMHO it had a few benefits and my wires are also from JB. Steve W was able to spec the dist and JB made it and the wires to Steves specs. It is a beautiful piece. Plus the wires are the nicest ones I have seen (especially after I got all the white lettering off of them). Anyway, a big thanks to Steve and the guys at JB. FYI, the motor is a 3.2ss with RSR pistons, 46PMO and mod s cams.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 10-09-2010, 06:10 AM
Wer bremst verliert
JohnJL's Avatar
Many thanks,
Christian
That's exactly what I run in my hot 3.0 with 40IDA Webers.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-16-2010, 07:56 PM
I have a Rennwerks twin plug with one MSD 6AL firing two blaster coils. It works well. If you want the full output of each coil you will need two boxes but some say it's not necessary.
Lindy
Old 10-18-2010, 08:11 AM
