cylinder wear tolerances
Could someone fill me in on cylinder wear tolerances on stock 1996 to 1998 993 cylinders.
Thank You
Old 09-29-2010, 12:06 AM
I would kindly recommend measuring your piston to cylinder wall clearances (in several places).
The cylinders "ovalize" more than they actually wear unless its swallowed a load of dirt from a bad air filter.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-29-2010, 10:31 AM
The factory wear limit for cylinders is generally 0.1 mm above nominal size. For a 100 mm cylinder the wear limit would be around 100.1 mm. As Steve says, you rarely find a cylinder worn above the wear limit. The ovality limit is 0.04 mm and is more likely to be a problem than overall wear. Matching the piston diameter to the cylinder diameter to achieve proper clearances is also important.
Tom Butler
1973 RSR Clone
1970 911E Restoration in Progress
Old 09-29-2010, 11:50 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
What happens if a piston is used that has smaller clearance to the cylinder walls then normal. Not jamed in there but half the recommended clearence.
Chris
73 911 E
Old 10-03-2010, 04:51 PM
If it is at the low limit it should be OK but any tighter then you run the risk of scuffing and early failure when it gets hot.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 10-03-2010, 06:56 PM
aws aws is offline
Actually the greater danger with Nikasil cylinders is to cold seize a piston in the cylinder, the clearances open up quite a bit as the cylinder heats up. I have had good luck running the skirt to wall down to.0011 inch with JE pistons with a hard dry film lubricant coating on the skirts in Nikasil cylinders.
aws
Old 10-04-2010, 08:23 PM
Oter
From the 993 Tech Spec book
Engine M64/05/06/07/08
Play: Cylinders-Pistons 0.02 - 0.03 (new condition)
Engine M64/20 RS
Play: Cylinders - Pistons 0.04 - 0.05 (new condition)
And from both the 993 & 964 Factory Workshop Manuals
Cylinder-to-piston clearance 0.02 -0.03
Old 10-05-2010, 01:41 PM
