Dizzy Rebuild
Can someone explain what recurving a distributor means and does it have to be done on a CIS system to Carbs and is it something I can do myself?
Thanks. |
In a nutshell, recurving a distributor means modifying the advance weights & springs to allow more ignition advance at a lower RPM for better throttle response and engine acceleration. The limitations are mainly octane and compression ratio.
You need a distributor machine to precisely measure advance at all RPM to achieve the desired result. Further, you need a selection of springs and weights to fine-tune the unit to get the values you want. Does this help?? |
Re-curving a distributor means changing the advance curve and limit, to maximize performance based upon your engine configuration, and driving preference.
What distributor do you have? Engine? Mods? Track, street, combo? Pictures? |
I am attempting to change a 2.7 CIS into a 2.7 carburetor. The build is going to be JE Pistons 9.5 CR, with E cams and 40 webers. The car will be street driven and i don't believe there is any special mods.
http://forums.pelicanparts.com/uploa...1286093007.jpg http://forums.pelicanparts.com/uploa...1286093030.jpg http://forums.pelicanparts.com/uploa...1286093066.jpg http://forums.pelicanparts.com/uploa...1286093095.jpg http://forums.pelicanparts.com/uploa...1286093140.jpg Thanks a bunch to the both of ya :D |
I would make sure your distributor doesn't have worn bushings or excessive end play when you recurve it. Most high-mileage ones need to be rebuilt.
.....the sound, I believe is similiar to, cha ching. Probably around 500 + for rebuild and recurve. You probably will not find anyone who is going to just recurve it, in a high milage condition.
Contact Aaron (Burn_bros) he is as good as they get at this kind of distributor service.
Rennwerks Inc. Aaron Burnham Camarillo, CA. 805-240-6931 aaronburnham@hotmail.com |
| All times are GMT -8. The time now is 04:52 PM. |
