-   -   2.4 to 2.7 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/568683-2-4-2-7-a.html)
BBShriver 10-08-2010 08:31 AM
2.4 to 2.7
I have a 73 911T, 2.4L CIS injection...
I've located what appears to be a good deal on original Mahle cylinders and pistons for 2.7.
A) Says they are nikasil cylinders, I assume this means aluminum material. Anyone ever have trouble with the electroplating? I assume they don't get honed and such like you do with iron liners
B) Would any crank-case modifcations be needed, or would this be bolt-in?
C) will 2.4 CIS heads work, or will I need to do something else with the heads and injection?
Thanks!
