 Pluging Tensioner oil line I may need to run the engine with the Hydraulic type tensioner (non-pressure type), but I only have the newer oil line for the pressure type tensioners. Is there a cap that will plug off the cam tower line to the tensioner? In other words can it be capped? |
 If you have the drop line to the tensioner you could cut it, removre the the connector and put a BB under it and it should seal like the fuel rail on a Carrera. Bruce |
 I'd hope there would be a cap, but sounds like a new oil line for the cam tower would the way. |
| All times are GMT -8. The time now is 02:39 AM. |
