Inside Centerlube covers
Could anyone post a close up picture of how the seals are attached to the cam box cover on an early car 901/01? I've seen one picture of the mag 906 covers and there seems to be a ring with three screws into the cover but it wasn't a close up.
I have seals and a 901/05 cover that I need to convert. I thought I got lucky and picked up an early left cover (here on pelican) with the hole for the dual fuel pump, but it wasn't center lube! Silly me, i assumed all motors with wobble nut pumps were centerlube equipped. Close but no cigar. Thanks in advance, tadd |
Tadd
Here you go... These came off a '65 911 motor with the Pierberg mechanical fuel pump, Solex carbs and center lube cams. Let me know if you need more detail. http://forums.pelicanparts.com/uploa...1287222891.jpg http://forums.pelicanparts.com/uploa...1287222951.jpg http://forums.pelicanparts.com/uploa...1287223020.jpg |
Tom:
Your brilliant.... Thanks! The last pic is perfect. I was told the seals were a press fit, then I saw the 906 cover and got confused. Off to the mill! Tadd |
| All times are GMT -8. The time now is 08:39 PM. |
