Oil pumps 4 rib or 3 rib? 2.4
I am sorting all my items out to make sure I have everything ready for my build. I have 3 3 rib oil pumps and one 4 rib oil pump. Is one better in some way than the other. Books say 4 rib is better, but do not know if that is true and why?
Building 2.4 w/2.2 S pistons. Will go in my 914/6 and plan on running a front mount oil cooler as well. If it matters.
Anyone have specs on the 3 rib vs 4 rib pumps? Which should I use and why?
2000 VW TDI 224HP/400FT TQ.
Pikes Peak World Record Holder 2007 "Fastest Diesel Car"
1973 Porsche 914/6 2.4L Engine rebuild in progress
Old 10-19-2010, 09:41 PM
IIRC the 4 rib is for engines with the oil bypass mod. Therefore the pressure side of the pump is larger and the scavenging return side is smaller....
So if ya got oil bypass mod, go with the 4 rib.
/Nimskov
Old 10-20-2010, 01:47 AM
Yes, the bypass mod was just done on my case.
Old 10-20-2010, 05:18 AM
The 4 ribbed as used through the Carrera
Bruce
Old 10-20-2010, 07:00 AM
bavaria911's Avatar
I am doing the same build. I have the 4 rib oil pump and Ollies machined my
2.4 7R case with the oil by-pass.
Vr,
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 10-20-2010, 08:09 PM
