3.4 which exhaust
Hi.
Just had a 3.4 built, twinplugged and 964 cams.
Just mulling over my two options for the exhaust.
I have aquired some 3.2 SSI's.
i would need to buy the oil pipes,gaskets and a new muffler.
I have have spoke to my engine builder about suitablility for the 3.4 and he thinks they would be good for it.
I have also contacted Steve Wong who was unsure wether they would be suitable.
My only other option is stick with the standard set up, which is in really good condition. It already has a cat bypass on and I would add a sports box to it
Your thoughts would be welcome.
Which way would you jump? I do not have funds for any other options..
Db
Old 10-25-2010, 11:35 AM
fred cook's Avatar
Exhausting choices..............
I would use the SSI exhausts. Depending on the other engine specs, they could be somewhat restrictive at high rpms, but should work fine other than that. At 3.4 liters, your engine displacement is just above the ideal for SSIs. Use them for a while, save your money and buy a proper set of headers if you think the SSIs are costing too much top end performance. I expect that you will wind up keeping them. Good luck with your project.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 10-25-2010, 01:32 PM
Another option would be a system based on 993 HEs .Rotate the exhaust flange on the pass side bank ,I forget if oil line changes are needed. If street driven they give you working heat and tube size appropriate for a 3.6. I have been told that the 3.2 SSIs are too small for a performance application and are more suitable to a 3.0 or smaller
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 10-27-2010, 11:52 AM
efhughes3's Avatar
I'd go with B&B headers. Less restrictive than the SSI's, and heat is an option. Some think SSI's are borderline for 3.2's.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-29-2010, 09:32 PM
