Advice on oil leak
Hi Folks
I recently rebuilt the top end of my '83 SC engine. I use the fancy RSR seals on the rocker shafts. With the car back on the road, and track, I ended up with oil smoke coming from the back but not the exhaust. The guys that followed me said it was coming from beneath the engine. I couldn't see any obvious leaks so decided to pull the engine, again. When I removed the rear tin on the driver's side there was definitely oil on the outside of the lower rocker shaft and I wondered if this place should be dry. I think so. And if there is high oil pressure then this might be a place where it squirts out, slides down the engine tin and then onto the hot heat exchangers. I've put some photos here at navCell and attached one of the lower rocker shaft. I would appreciate anyone's comments. Thank you in advance. Dave
Did you torque the rocker shafts to 18 lbs.? Could be problems with the cam tower but probably just needs more torque.
You need to post a couple more pictures because I cant tell which rocker or rocker boss we're looking at.
The shaft should be flush or just above flush on the thin boss side. If the rockers are moving you might find that is a leak even with the seals There is only splash oiling, no pressure Bruce |
