flat6pilot's Avatar
Megasquirt-II Questions
I'm upgrading from an MS-I (Tony Bitz kit) to an MS-II daughtercard.
I plan to do ignition in the future (collecting pieces now) but would like to use the fuel side of the MS-II in the meantime. Are there any issues with this and the MS? I have not done any "Ignition/IAC" jumper mods to the boards yet. Just installed the daughtercard and loaded the firmware.
I have most of my old MS-I settings installed but I'd like to see what another 3.0l from a 911SC MS-II file looks like to compare.
If you have a file or some screenshots you could send me that would be great.
Two other things:
1-My fuel pump continues to run with the engine off (didn't do that with the MS-I) Any ides?
2-Under "Injector Characteristics; Injector PWM period" it is default @ 66. This was the only thing that MS-I didn't have on it's settings. I left it at 66 for now.
Thanks for any insight.
-Kyle
* 1980 911SC - 3.0l R.o.W 8.6:1 w/ Garrett 30R turbo conversion (.5 bar), Bitz MS-II EFI, Carerra intake, Zork tube, 2300lbs, 360whp
Old 11-06-2010, 02:23 PM
