964 case, what is behind this plug
This is a 964 case (993 motor) Can anyone tell me what is behind this plug? Can I remove it without disturbing chain ramps etc? (It appears to be a potential location for a turbocharger drain. I'd like to investigate...)
http://www.members.shaw.ca/imupnorth/turbodelete5.JPG |
HI Jim
the bolt holds the chain ramp, also the one above, use the drain plug or fit a 3.3 turbo return pump in the L/H cam and a small catch tank to the bottom of the turbo to return from, the oil can cool in there before re-turning to the oil tank. regards mike |
Thanks Mike. I'll go back to my original plan now and use the drain plug.
| All times are GMT -8. The time now is 02:08 AM. |
