2.4/2.7 Con Rods
I have been looking at rods for a 2.4 engine and the centre to centre length seems to vary.
Wayne's Book gives a dimension of 217.8mm but I have seen rods specifed as 127.7 and 127.75.
I am sure that this small difference isn't too important but wondered if there was a specific reason?
Old 11-22-2010, 09:03 AM
304065's Avatar
Chris,
I think it's 127.8, here is my logic
2,0 and 2,2 = 66mm stroke, 130mm rod, 34mm compression height = 197mm from centerline to deck
2,4 = 70.4mm stroke, 127.8mm rod, 34mm compression height = 197mm
same geometry, remember that the 2,4 heads and the 2,2 heads are the same (for the pundits who will claim the geometry was different due to the cylinder/head interface.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-22-2010, 10:03 AM
Rods
Makes perfect sense - Thank You
Old 11-23-2010, 08:29 AM
