Is this going in the 914 project car? This is the engine with those Titanium valve spring keepers, right?
Yes, it was going to go in my 914/6, but now it will be taking up residence in my '74 911, hence the 911 sheetmetal. |
OK. You still have the 914 project in a holding pattern, right? You have not sold it?
It has been a while since I have been down to the shop. :) |
Happy Father's Day to Tony. SmileWavy
Hey Steve,
What is the story with those 1 inch tall spacers between the manifolds and the heads? And what did you coat the PMO manifolds with to get that mag look? dug Quote:
I would suspect they allow a better transition between the ports and intake runners- tapering into an anti-reversion step, along with providing some thermal insulation for the carbs from the hot metal heads.
| All times are GMT -8. The time now is 07:14 PM. |
