-   -   No-8 o-ring seal. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/575985-no-8-o-ring-seal.html)
quattrorunner 11-18-2010 10:25 PM
No-8 o-ring seal.
So I did a great job of assembling my crankcase. Forgot the o-ring on the no 8 bearing. Awsome.
brads911sc 11-19-2010 04:33 AM
wow. that sucks. i feel your pain. i am looking forward to making similar blunders. hopefully you can get it apart and fixed without having to buy more parts...
lindy 911 11-19-2010 06:11 AM
I did not forget my O-ring but mine would probably seal better if I did. I put it in with a light coat of oil and although it didn't leak in the beginning, it leaks like a sieve now. Tempted to just glue the joint but that just wouldn't be right.
Lindy
LUFTMAN 11-19-2010 10:36 AM
lindy that will not help been there done that . they do make a oversize o-ring also paint some light coating of permatex (non hardening) around bearing and o-ring groove . this has been a sore spot on these engines for a long time. good luck regards tom
