2nd tIme I did it I built a basic hoist with 4x4's and a comealong. Worked perfectly. Have a pic somewhere.
Chrishttp://forums.pelicanparts.com/uploa...1649259024.jpg |
Lift tables are what we use. But we routinely have 3-7 engines on stands so it makes sense to have 3 lift tables. We use the table for engine removal/install and on/off engine stands. Super easy. Not necessarily the best option for DIY one time use.
I have one of the jack adapters we bought years ago to do it on a floor jack. It worked for in/out but you need a really high lift jack to get it onto a stand. |
+1 for using a lift table. Makes it much easier.
regards, al |
Lift table is the best way but if you have a hoist (2 post) you can also use one or two of the arms to raise and lower your engine. Just strap it to an arm.
Had the lift tables occupied, used Henry's idea with the 2 post. Worked great. very easy.
Cheers |
Hi everyone,
I made a video of my son and I moving engine from stand to lift without a cherry picker. I don’t have the very first step but describe it in the end. It’s on my YouTube page. Here’s the link: https://www.youtube.com/watch?v=BX2jOT9BeK4 Cheers, Mark |
This is how the Pepe’ (tiny dog) and I do it.
Getting the engine on the stand was easy. http://forums.pelicanparts.com/uploa...1650068338.jpg Getting it back down was difficult. I had to find something tall enough to support while allowing me to fit an ATV jack under. Then lower it in increments. Jenga anyone? http://forums.pelicanparts.com/uploa...1650066576.jpg http://forums.pelicanparts.com/uploa...1650066576.jpg http://forums.pelicanparts.com/uploa...1650066576.jpg http://forums.pelicanparts.com/uploa...1650066576.jpg http://forums.pelicanparts.com/uploa...1650066576.jpg |
Some of the Scariest Things We Do..........
Tony |
If you’re a gearhead or enough of one to R&R your own engine, it’s worth getting a cherry picker. They pop up on Craigslist now and then for dirt cheap money. You’ll end up using it once you have it, saves your back, and allows you to solo a lot of projects that would have required more coordination with helpers. And lending it out a lot. http://forums.pelicanparts.com/uploa...1650124363.jpg http://forums.pelicanparts.com/uploa...1650124363.jpg http://forums.pelicanparts.com/uploa...1650124363.jpg http://forums.pelicanparts.com/uploa...1650124363.jpg |
| All times are GMT -8. The time now is 05:46 AM. |
