-   -   oil hose rotating on pipes (http://forums.pelicanparts.com/911-engine-rebuilding-forum/577368-oil-hose-rotating-pipes.html)
Chris Morse 11-27-2010 10:31 AM
While cleaning up the blown out thermostat mess i noticed that the hoses rotate on the steel lines going to the cam housings. Is this normal??? They look good and don't leak.
never seen this before,
chris
Flat6pac 11-27-2010 06:26 PM
They are getting old and brittle..time to change them
Bruce
Chris Morse 11-28-2010 08:17 AM
Hi Juan,
I believe they were replaced 10k miles, (also 10 years ago - my dad didn't drive much).
Both metal ends are secure and don't leak but the center section of rubber hose, (including the crimped ferrull) rotate easily on the pipes but don't appear to be leaking.
Is this normal?
john walker's workshop 11-30-2010 09:35 AM
not normal. get some new ones.
Chris Morse 11-30-2010 05:41 PM
Hi John,
This didn't seem normal to me either. Thanks for the input. I'll order two new asap.
Thanks,
chris
BoxsterGT 12-02-2010 11:52 AM
The rubber has gotten hard enough to no longer grip the fitting.
A leak is just around the corner. Definately need to replace them.
Len
piggdekk 12-05-2010 09:50 AM
It did happen on my former van on the lines to oil cooler. One of them was already leaking the other just moving into the fittings. Change them before they make a big mess.
