-   -   1987 3.2 Cylinder Head Temp Sensor (http://forums.pelicanparts.com/911-engine-rebuilding-forum/577614-1987-3-2-cylinder-head-temp-sensor.html)
shrtshck 11-28-2010 06:43 PM
Any suggestions on how to remove the cylinder head temp sensor. The wires appear to be permanently attached so I can't get a standard socket over it and there doesn't appear to be enough room around the sensor to get an open end wrench on it.
Any ideas, I would rather not ruin the sensor?http://forums.pelicanparts.com/uploa...1290998599.jpg
Flat6pac 11-28-2010 06:57 PM
Just cut it off and then a 14mm deep socket will fit it.
Bruce
johnman001 11-28-2010 08:10 PM
I made a tool out of a Harbor freight sacrificial 14mm deep socket. Don't tell me Harbor Freight tools aren't good for something.
Usually, when I need to make a tool, I'll stop by Harbor Freight to see what I could cut up to make work.
shrtshck 12-01-2010 03:31 PM
Good suggestion John
Our Canadian Harbor Freight equivalent is Princess Auto, picked up a cheap 14 mm deep socket for the task.
Slowly adding to my collection of "special" 911 tools
