-   -   964 Cam Part Number Check......... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/578201-964-cam-part-number-check.html)
fred cook 12-02-2010 08:42 AM
I have a set of 964 cams to go into my 3.3L rebuild, but want to verify the part numbers. One is 964 247 1 165B and the other is 964 246 020D 1. Just want to make certain that these are for a manual transmission/NA engine.
Thanks,
Flat6pac 12-02-2010 01:35 PM
Pet shows application for 964/01/02 which are 964 either wuto or standard. The grind is standard for Euro, US and automatic. What the spec is for the application is the thing that changes. The only factory spec I ve ever seen is 1.26mm.
Bruce
lucittm 12-02-2010 05:56 PM
Fred,
Pictures of the cams would be great. For instance, do both of the cams have the accessory drive for the PS pump and the turbo oil scavenge pump?
Thanks,
Mark
