-   -   Would You Start With a 3.0, 3.2 or 3.6? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/578483-would-you-start-3-0-3-2-3-6-a.html)
jamesjedi 12-09-2010 01:17 PM
3.3 FOUND - Please Help me Decide.
I found an engine. I need to know if someone would pay $3000 for it??? I am going to let the seller know today. THANKS!!! It is a 3.3 tubo engine, that I would covert to an NA. It has following, and work has been done professionally;
Perfect Case, rebuilt and resealed
Micro-polished crank with standard size main and rod journals
New main bearings
New rod bearings
New intermediate shaft bearings
Oil pump
New chains
New rails
New rod nuts and bolts
6 bare cylinder heads (not installed on engine)
Chain housings (not installed on engine)
Chain covers powder coated yellow (not installed on engine)
Upper valve covers powder coated yellow (not installed on engine)
Lower valve covers modified for twin plug, also yellow (not installed on engine)
Fan housing
Alternator
Fan
12 rocker shafts
12 rockers
Both cams in perfect condition
Cam housings (towers)
Factory top fiberglass air shroud
Not included:
Sheet metal air shrouds
Pistons and cylinders
Exhaust
Turbocharger
Intercooler
Intake system
Engine harness, etc.
Advice would be great!!
Steve@Rennsport 12-09-2010 01:28 PM
Find out WHO rebuilt it.
Might be a bargain and might be a nightmare. :) :)
jamesjedi 12-09-2010 01:39 PM
Thanks for replying Steve. It was built by Al Bro#df##t. It is a 3.3, I will correct the original post. I erroneously assumed that the 91 Turbo was a 3.6, they were 3.3. That means that this engine can only be bumped up to 3.4 without splitting the case?? Or, without using thin walled cylinders.
Steve@Rennsport 12-09-2010 02:06 PM
You can make it a 3.4 without doing any machine work. Anything larger will require case modifications or thin-walled cylinders.
jamesjedi 12-09-2010 02:13 PM
3.4 on 93 octane would be good for 250, in an unstressed engine??? I am really starting to like the 3.6.
lindy 911 12-09-2010 03:00 PM
I built a 3.0 that had Mahle cylinders. It went like this:
Stock crank checked and polished.
Stock rods re-bushed and re-sized, balanced.
Stock SC oil pump.
Raceware rod bolts.
Supertec studs
Rebuilt '78 SC heads with race springs and retainers.
JE 10.5:1 pistons.
46 Webers.
Equal length headers no heat.
GE60 cams.
At this point I spent about $7500
Rennwerks twin plug distributor.
MSD 6AL with twin coils.
This set-up cost about $2,000
No dyno time yet but experts in the know say 275 hp at the crank. The seat of my pants say see'ya 350Z. This combination runs REALLY hard. It's a little pipey but I like that.
http://forums.pelicanparts.com/uploa...1291935532.jpg
Lindy
jamesjedi 12-10-2010 07:25 AM
Can the case be rebored without splitting it?
lindy 911 12-10-2010 07:44 AM
No
AlfonsoR 12-12-2010 11:32 AM
Steve, what are is the real world down side of thin wall cylinders? Logic says a thinner wall will be less geometrically stable, leading to less longevity or at least more blow-by at higher temperature. What have you seen?
jamesjedi 12-12-2010 12:03 PM
Lindy, that is a nice build for $7500. I am also curious about these thin wall cylinders. I think that they are called "slip on"? Perhaps is it a predictable answer.
Steve@Rennsport 12-12-2010 04:45 PM
Thin-walled cylinders oftentimes lose concentricity due to normal heat cycling and that leads to loss of effective ring sealing. This increases blowby and oil dilution.
We are quite careful about what cylinders (and sizes) we will use or sell anymore.
jamesjedi 12-12-2010 08:35 PM
A BIG thanks to Steve for his contributions to this thread. THANKS.
