Cleaning Fluid
I bought a parts cleaner to clean many of the engine parts of my rebuild myself. Question is what solvent should I use? I looked at some waterbased cleaners, but they state that it will harm aluminum. I had someone else recommend mineral spirits, but it is combustable and the manual for the parts cleaner states "no flammable or combustable cleaning fluids.
What should I use? |
E-85 sippin drunk
Mineral spirits.... nothing else... I bought a parts cleaning tank form Northern Tool, Same as the Harbor Freight one.... for around $100 bucks... I use about 15 gallons or so of pure mineral spirits for the last 10 years... only changed out the fluid once... Works great
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
mineral spirits works, there are threads on this.... diesel fuel has been described as working pretty well and doesn't cost too much but may need soaking
I am a fan of kerosene with ATF added, just because it is cheap and the smell is not too bad.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Kerosine and ATF...wow who thought of that mix?
Anyway I went ahead and bought 10 gal. of Mineral Spirits and am currently out in my driveway clean parts. Thank for your input. The Mineral Spirits seem to be working OK. I thought it might clean a little faster. But that might be because its 25 deg. outside. |
Mineral spirits, also called ******** Solvent.
Works well, cleans off easily, isn't terribly flammable, and doesn't leave everything smelling bad.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com Last edited by Steve@Rennsport; 12-11-2010 at 11:49 AM.. Reason: The name was blocked as its the same name as a Porsche dealer in Ohio |
Chain fence eating turbo
Naphtha is what I used, works great.
