ARP bolt fitment, help!
I bought these ARP conrod bolts for my 2.0S conrods and they just
don't quite fit. The shoulder of the cap won't push past the shoulder of the conrod with hand pressure. So, do I: a. send them back b. machine the conrod, it doesn't need much by the look of it c. force them, it's pretty close and it looks like it might be possible to force it down http://farm6.static.flickr.com/5248/...2d9d731b_z.jpg Arp, on Flickr andy |
Regardless of type, they dont always seat. I always tap them with a hammer to seat them, resting the edge on the table to make the tap work to seat.
Bruce |
Massage the rods so the bolt goes in without any side loading.
There was a batch of improperly machined bolts sent out by ARP a few years ago and these look like one of those sets. If you force it in the bolts actually point to the center and create a undesirable load at the cap end of the bolt. |
"massage"? with a file?
I am merely an amateur, hence the amateur question. andy |
When we encountered that issue we used a mill but a file will work just fine.
Thanks for the advice Henry. Another question if I may:
Why did you not modify the bolt cap rather than the rod? andy |
Rod bolts are far, far more stressed than the cap. Notches create stress points where failure can occur. It is usually not wise to modify a critical high strength fastener. The high strength, high yield point fasteners require extra care.
t |
surface once the clamping force is applied. It just stops the bolt from turning initially until the clamping comes into effect. I'm thinking ease of machining will be the critical decision point which will lead me to modify the rod cap rather than the bolt cap. andy |
I have to disagree. A surface defect in a notch sensitive material will be a problem even if it's not in the direct load path. I've seen high strength fasteners fail just from shortening the threaded portion which is out of the load path given it's on the other side of the nut.
t |
Why can't you send the bolts back and get new ones that fit?
It's times like this when you appreciate the value of dealing with good/great vendors. -Chris |
ARP have offered to replace the bolts and pay shipping both ways which
is very professional of them. I have declined the offer since I already modified the rods to accept the larger end cap bolts. andy |
| All times are GMT -8. The time now is 09:37 AM. |
