-   -   Intermediate shaft questions (http://forums.pelicanparts.com/911-engine-rebuilding-forum/582431-intermediate-shaft-questions.html)
AlfonsoR 12-28-2010 10:58 AM
Guys, i've been doing some research on intermediate shaft. My car is an 89 3.2 with 105k miles on it, i've had it for about 6k miles.
I'm planning on doing an engine drop in the next few months to repair some oil leaks, and am leaning towards opening up the bottom end only because I've seen a few posts where people have opened up the bottom end and found copper showing on the IS bearings. So here go the questions:
1. I want to figure out how to repair or replace IS bearings, gears and shaft so that my engine bottom end will run to at least 300k miles or more. So I think I have to figure out what causes some engines to show copper in the 80-100k mile range, while others report their 3.0s and 3.2s run 200k miles without opening the bottom end. Is it poor maintenance or poor lubrication properties of the oil being used?
2. Are there any upgrades worth doing to ensure longer service life? I have read you can use straight cut gears, which takes out the thrust component of the helical or angle gears, but yes I have also read these things are loud. Is anybody running straight gears on their street car? Are the gears loud in a good way? Maybe the straight gears will make my engine sound like a Lambo V12. :D
Thanks for your help.
BURN-BROS 12-28-2010 02:26 PM
It is common to see high wear at the IS bearings even with low hour motors.
I would not recommend splitting a case. If you did the wear would be right back. These engines can last for quite a long time if you do the maintainance.
brads911sc 12-28-2010 02:57 PM
if you open her up get the bearing treated at WPC. reduces friction by 50% and doesnt change tolerances... many guru's including charles navarro swear by it...
AlfonsoR 12-28-2010 08:41 PM
Aaron, at what point would you recommend the case be opened to check the intermediate shaft? I think I read where someone lost the aluminum gear and caused serious damage to the engine.
Does the same wear occur with straight tooth gears?
Flieger 12-28-2010 08:46 PM
I have heard that the wear on the intermediate shaft bearings are mainly from the chain tension on the end of the shaft causing a moment within it.
AlfonsoR 12-28-2010 08:49 PM
Brad, I live in Missouri City. Where did you get the WPC coating? I see they have several offices.
Looking further down the slippery slope, errr mountain side, I might replace all the bearings and have those coated too. Hmmmm...wondering if it would be worth doing a thermal coating on the pistons and valve bowls even if I re-use the ones in there? Also wondering if I have Nikasil cylinders? Just a bunch of random thoughts popping in my little brain.
Also, where did you get your machine work done and engine components checked out? i.e., if I do the split, I would want someone to inspect the bearing clearances and journal diameters. I have a set of mics but I don't do that stuff enough to trust myself.
lindy 911 12-29-2010 07:06 AM
If you have your motor out and on a stand to do a top end, it's not that much more involved to split the case. If you have a concern about the bearings go for it. You might pull the cap from one of the rods and get an idea of the bearing condition for that rod. If it looks good, chances are that the rest of the bearings will look the same.
There are some good sources for the work you're looking for right here in the Houston area. I used Poly-Dyne for the coatings on my bearings and piston skirts. They also did the thermal coat on my pistons. It's different technology than that used by Brad, but a lot of the hard core race motor builders in the area think it's best.
Depending on your schedule, William Knight is moving to Sugarland in January. He would be an excellent choice for the inspections you are seeking. Mike Callas is also pretty good, from what I understand but be prepared to open your wallet.
There is a ton of very useful info on this site. If you take your time and do some research, your rebuild will be a piece of cake.http://forums.pelicanparts.com/uploa...1293634794.jpg
http://forums.pelicanparts.com/uploa...1293634883.jpg
http://forums.pelicanparts.com/uploa...1293635131.jpg
Lindy
BURN-BROS 12-29-2010 07:17 AM
Hi Alfonso,
When it's time to replace main bearings or you have a leak that requires splitting the case. It's not a potential issue that I would use as an excuse to split the case.
Now if you are dieing to split the case, by all means replace. However, the upgrade I would do on a 3.2 would be ARP rod bolts and the bearing coatings are very nice.
You will need to have the rods resized if you upgrade the rod bolts.
AlfonsoR 12-29-2010 09:15 AM
Lindy
Hi Lindy,
Thanks for the info on the coatings and yes, I would be interested in getting contact info for William Knight. I am in no hurry and as a matter of fact, before even pull the engine, even if I don't split it, I would like to sell the car next to my 911. It's a 88 BMW 635 that I dont have room for and that needs a little interior work. Selling the bimmer will finance the work I do on my 911 at least for this year. So it will take a few months, I'm sure.
I had a PPI done by M Callas a while back, and he's a great guy and obviously very knowledgeable but besides the wallet factor, it's quite a drive for me and I don't have that kind of schedule flexibility with respect to missing work to go check on things...I like to be at the shop as much as I can just to learn, so I was looking for someone a lot closer. Mr. Knight might be the perfect fit.
AlfonsoR 12-29-2010 10:18 AM
Originally Posted by BURN-BROS (Post 5752219)
Hi Alfonso,
Hi Aaron, thanks for your input. I really appreciate the advise.
I think I do have a slight leak, more of a weep, on the case split line. The main oil leak is coming from the oil cooler and possibly the breather too.
Your comments make me breath a little easier.
Do straight gears solve the bearing issue? How much louder are straight gears?
PS: what do you mean by resize the rods for ARPs? I'll do some research in the mean time.
Thanks again!!
AlfonsoR 12-29-2010 11:37 AM
Aaron, so re-size is necessary because the ARP rod bolts provide more clamping load which changes the shape (makes them out of round) of the rod, correct? So the bolts need to be installed then rods need to be bored to make them round again.
Does this mean new bearings would be necessary? If so, what do you recommend?
Flieger 12-29-2010 12:02 PM
I do not think the straight cut gears will solve the bearing wear issue. The thrust is axial, not radial, and the bearing does not support that sort of load. It would wear the bearing shoulders or any thrust bearing surfaces.
burgermeister 12-31-2010 08:39 AM
I installed ARP rod bolts on my engine and did not resize anything. I plastigaged the rods & bearings on the crank and everything was in spec.
Caveat: I am NOT a rebuilding expert, and my engine is still in the reassembly process.
brads911sc 12-31-2010 11:16 AM
WPC is in CA. I shipped them to CA. Had them back in a week. Total for all Main, Rod and Intermediate bearings was $140 Incl shipping. Cheap insurance.
The Poly Dyn is also very well regarded. I chose WPC because I didnt want to mess with clearances. Its a micro shot peen with tin and other anti wear material.. Poly Dyn is similar materials but is a coating. Both are probably equally good.
In Houston, Id use either M Callas in Sealy (Who I used) or M Crawley at European Auto Technics. Both have old shops filled with old Porsches and have on site machine shops. Both are spendy. My machine work was $800 and its an SC case that didnt need anything. that included having him install the rings and cut them (where needed) (extra $175). Was worth it to me to have that perfect. As a side note.. He didnt install my new wrist pin bushings. Said mine were fine and advised me to use the old ones. So he def isnt trying to sell u extra unneeded work. He marked my pistons based on where he would install them. Very stand up guy...
At either shop Id plan on dropping them off and leaving them for a week...
BURN-BROS 12-31-2010 01:06 PM
Yes.
I do. It's not worth it not to.
BURN-BROS 12-31-2010 01:36 PM
Resizing rods takes care of two potential issues
1. maintaining roundness.
2. The Circumference dimension or "bearing crush".
You can obviously install rod bolts and run them without the engine blowing up, but the variance can result in tight spots and loose spots on different areas of the rods. This is not easy to see with a Plastigauge. It will however show up with a bore gauge.
The circumference dimension is particularly important in controlling the bearing from walking especially under higher loads/rpms.
Resizing is a step that everyone should do as the potential problems far outweigh the cost to have the procedure done.
Walt Fricke 01-02-2011 09:08 PM
The "copper" showing on my IS bearings has been on the thrust surface. The radial surface looks fine, but the thrust part looks worn. The #1 main bearing (which is a thrust bearing) has the same issue.
I assume that thrusts from the helical (or whatever they are) IS gears is partly to blame for this. Of course, the clutch also imposes axial loads.
I have straight cut steel IS gears in my 2.7 race motor. But I run straight pipes, so no way to tell about noise. And the current build of this motor has lasted quite a few years, and I don't recall if I have pulled it down since the straight cut gears went in to see if they made any difference.
However, basically this wear on thrust surfaces isn't something one needs to worry about. The rod bearings go first, and while those can be changed without splitting the case, why do it that way? Most just pull everything apart at that point, and all bearings get replaced.
burgermeister 01-03-2011 02:45 AM
As another point of reference, my IS bearings did show copper on the radial surface at 163,000 miles. Also the thrust surface of the IS & crank thrust bearings like Walt mentioned. The most worn parts on the engine, aside from the valve guides, were the rocker shaft bushings.
Flieger 01-03-2011 09:36 AM
How is the end float with the straight cut gears? (axial play)
gestalt1 01-03-2011 04:33 PM
I have a related question, how about on early sand cast cases- is the thrust wear just the shoulder of the intermediate shaft and the aluminum case? These cases have no bearing. I would think a stair cut gear set would help reduce wear quite a bit because there is no thrust forces. Any experience with this?
Walt Fricke 01-03-2011 05:21 PM
Max - axial play on all except the early cases/IS shafts is taken up by the double thrust bearing and the shoulders on the IS shaft which are on either side of the thrust bearing. Was that your question?
Gestalt - the axial thrust for the early sand cast case IS shafts which is to the rear is taken up by the cast iron external cover plate. Because end play is adjusted on these shafts by varying the thickness of the gasket between plate and case. This is a well lubricated area, because you don't see wear marks on the cover plate - at least not worrisome ones.
For some reason I am drawing a blank as to what resists thrust pointed toward the flywheel on these cases, but it has to be a flange or equivalent bearing on the case itself at the rearmost bearing web. Which is also well lubricated, as this is where the pressurized oil lubes the bearing area, and also enters the IS itself in order to lubricate the front bearing area.
AlfonsoR 01-03-2011 07:14 PM
Thanks for the info Brad. If I split the case, I will go for "perfect" too. I might even upgrade to Pauter or R&R rods, if budget allows.
What brand of bearings and rings did you use?
brads911sc 01-03-2011 07:57 PM
Bearings were all Glyco.
Rings were JE Pro Seal. I also have the 9:5.1 JE Pistons.
AlfonsoR 01-03-2011 10:32 PM
Thanks Aaron, Max, Burgmiester and Walt for the information.
It looks like it's as Aaron suggested, that as soon as you start your freshly rebuilt engine, the IS thrust bearings will begin to wear and will show copper shortly thereafter.
I still have not heard personal experience on straight cut gear and whether that improves IS radial or thrust bearing wear. I hope someone can chime in on this.
lindy 911 01-04-2011 07:17 AM
Since the stock IS gear set up will produce a thrust load by design, it only makes sense that the straight cut gears will not. I would wonder why Porsche used the stock set up in place of straight cut gears as the latter is easier to manufacture. I suspect noise and added surface area of the teeth have a lot to do with it. I would also suspect controlling the back lash of the two gears is easier with the helical cut.
Unless you plan to build a race motor, non-stock rods are not necessary. The money for Pauter rods would easily pay for a perfect bottom end rebuild including re-sized Porsche rods with ARP bolts.
My motor came out at 97,000 miles. Stock '78 SC with some hard miles. The thrust sides of the front IS bearing were in good shape, not perfect but it could have lived happily for many more miles. The second bearing near the pump shaft joint is where the wear showed the most. This is not a thrust bearing simply a plain bearing supporting the pump shaft end of the IS.http://forums.pelicanparts.com/uploa...1294153933.jpg
http://forums.pelicanparts.com/uploa...1294154045.jpg
AlfonsoR 01-04-2011 07:59 AM
Thanks for the comments Lindy. I found Michael Knights info on the web. Once I figure out what I want to do, I will contact him.
I only mentioned the upgraded rods because I was thinking of future proofing the engine, as in, I have an eye on possibly (key word there) upgrading to a Protomotive type set-up somewhere in the future.
Any way, the top-end has been done. And if I upgraded the bottom end, "all" I would have to do is look at cams, turbo, and exhaust. A sort of piece-meal way of upgrading to 350 hp or so.
