-   -   Yet another Dilivar head stud question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/583450-yet-another-dilivar-head-stud-question.html)
vytenis 01-03-2011 02:57 PM
I have Wayne's book and have read a number of posts regarding "the ticking time bomb" of Dilivar head studs. I have an '87 911 with Dilivar lowers.
Quoting Wayne from his parts catalog "As the displacement of the 911 engine increased over the years, the increased stress caused by differing thermal rates of expansion often caused the head studs to break or separate from their mount in the case. This often resulted in a leak between the piston and the head. Porsche decided to solve the problem by using Dilavar studs. However, there were reports of these studs breaking under pressure prematurely. There are a few good solutions. You can replace your studs with the standard Dilavar studs that the factory began using in 1984. Or you can use high-strength aftermarket studs."
I've read that they keep making the Dilivar studs better and better. I'm doing a top end rebuild at 100K miles (and while I'm in there) and don't want to cut any corners. Nor do I want to drain my bank account unneccesarily.
So are Dilivar studs after 1984 OK for use on a stock engine configuration?
"V"
Steve@Rennsport 01-03-2011 03:16 PM
"V"
IMHO, yes indeed, provided you use the late 993TT ones.
tom1394racing 01-03-2011 05:04 PM
The Dilivar studs used on the 3.2 Carrera and later models were the coated type.
I have not seen the corrosion related failures on these that are common with the lower Dilivar studs on the SC motors.
Comments??
Jesse16 01-04-2011 05:30 AM
Similar question here
I have a similar question regarding the Dilivar head studs. I've got the engine out of my 87 Carrera for a top end job and some leak management. All the head studs seem fine to me. Car has 187k miles and this is the first engine apart work ever. Car has always lived the rust free life so the question is, any grave consequence to just leave well enough alone! Not hard to convince me to just leave em for now and make a quick check at each valve adjust going forward. Hate fixing stuff that isn't broken.
Carrerax 01-04-2011 07:15 AM
you can also just use the same steel studs as the top row and be fine. They are availailable here at PP or I know Tom1394racing will sell you used ones for very inexpensive. They are not known to break.
brads911sc 01-05-2011 06:28 AM
Dump them, 993TT or otherwise and use Supertech. Half the price and better product...
"V"
vytenis 01-07-2011 05:00 PM
The Porsche engineers used Dilivar on the bottom for a reason. I know that the ARP, Raceware, Supertech headstuds work, but it is overkill ($) for me. Going to go with the new Dilivar bottom studs.
brads911sc 01-07-2011 05:47 PM
Overkill ($)? the Supertec is $610 for 24 the Dilivar is $1128 for 24 with washers/nuts... Supertec come with a lifetime warranty. Dilivar does not. Dilivars have failed. Supertec have not. Seems to me you have it backwards ($)... I wouldnt put Head Studs in the list of briliant porsche engineering successes... Im just sayin...
tom1394racing 01-07-2011 06:01 PM
On a stock motor, a good set of used steel studs for the bottoms will be just fine.
Flat6pac 01-07-2011 06:44 PM
On street use, I never have had to apologize for failure. When the 993 dilivars were a buck more that the stock dilivars I would install them but now I wont even retorque dilivars, Ive woke up the next morning with nuts and stud pieces on the floor.
Bruce
Flieger 01-07-2011 06:49 PM
Bruce, you use steel, then? What if the customer is willing to pay the money for the 993 studs or whatever is best. What do you use then?
roy gray 01-08-2011 09:58 PM
steel
just use steel.the germans continue to reinvent the wheel unsuccessfully while the japanese perfect their original designs and put out a superior product.a 911 motor,especially a street motor doesn't need dilavar ever.or
"aviation"grade.just use steel.
ALEX P 01-09-2011 01:20 AM
Headstuds seem to be a real achilles heel on all 911's particularly SC's but now that 3.2's and 964's are all getting past 20+ years IMO they are going to cause more and more issues in the later cars.
I went through a similar decision for my rebuild and the choice came down to using the 993TT studs (the fully threaded ones), Supertec or Racewear ones. 993TT and Racewear ones were ruled out due to OTT price and I bought the Supertec ones. Seem to get good reviews from everyone who have used them, best priced and you can't argue with a lifetime warranty.
ChrisBennet 01-09-2011 06:31 AM
Comments??
As a data point, I replaced a broken lower head stud on a friends 3.2 a few years ago so it does happen. I agree that it probably isn't very common.
-Chris
Henry Schmidt 01-09-2011 07:23 AM
The best choice for every aircooled Porsche engine is Supertec studs.
You don't need them just like you don't need a Porsche to drive to the store. You can just get in your Yugo and trundle on down the road.
lindy 911 01-10-2011 06:47 AM
vytenis,
I would never recomend this but since you have made up your mind to use dilivar I'll save you the purchase price of new ones and send you the ones I got from Porsche brand new for free. I have all the new studs for the bottom except one. You'll have to buy that one because when I installed these brand new studs in a '78 SC, not an hour went by until I heard a "PING" and one of the studs turned into a projectile.
FWIW, I have Supertec studs now and they are far superior to what Porsche did, overkill or not. Send me a PM with your address and I'll send you the studs.
Lindyhttp://forums.pelicanparts.com/uploa...1294670575.jpg
IDGAF27 01-10-2011 08:23 AM
Originally Posted by lindy 911 (Post 5774885)
vytenis,
+100. WOW, that speeks for it self.
Vytenis imk kas geriau. remontuoti antra karta brangiau, negu padaryti teisingai is pradziu..........
vytenis 01-10-2011 09:11 AM
Aciu
Cogitating!
"V"
shrtshck 01-10-2011 05:24 PM
For what it is worth, I just replaced the Dilivars on mine with the standard steel ones. As with you I have a 87 with 100k miles, none of the Dilivars were broken but it is good insurance based on the experience of others. I'm happy to say that all the Dilivars came out without issue, 5 to 10 minutes with a propane torch and they came free.
vytenis 01-12-2011 03:03 PM
vytenis,
I'll bite. PM Sent. I am going to fixture in a jig to test bolt preload and will share results here. Might snap some. While I am not a "boltologist", I did design bolted joints in a previous life. I have a little time in my rebuild before I'm ready for head studs.
"V"
lindy 911 01-12-2011 03:30 PM
Studs are on the way. Don't worry about the postage.
Lindy
Flieger 01-12-2011 04:17 PM
I am very interested to hear the results. :)
Henry Schmidt 01-12-2011 04:24 PM
If you need studs for your test, PM or email me and I'll supply some.
I think I have:
ARP
Raceware
Supertec (of course)
993 TT
Super Stud
Coated Delivar
MM
Factory steel
AlfonsoR 01-12-2011 04:49 PM
I have some dilivar studs as well with about 100k miles on them. I would be happy to send some to you for your test.
Please tell more about how you will test and what the goal is. Do you have John Bickford's books? Perhaps you could run the test at different temperatures to simulate the temp they are normally exposed to.
I think Charles N or maybe Henry might have info on thermal expansion coefficient of the cylinders. I wonder if there is any difference between the Nikasil vs Alusil?
I would be looking to determine the bolt loading cold vs at temp, and you might have to develop some correlation between cylinder temp and stud temp...
vytenis 01-12-2011 06:11 PM
Working on a plan... I have access to a shop to build some fixtures.
No doubt the Porsche case/cylinder/head/stud assembly is complex given the materials and loading situations.
We'll start simple and work our way up. I would like to understand the mechanical design aspects of this bolted joint. Long term effects such as corrosion and hydrogen embrittlement, which have been mentioned as causes of failure are out of my league.
My first curiosity is why 993 Dilivar studs would fail after initial pre-tensioning, without any other loads.
"V"
AlfonsoR 01-12-2011 08:09 PM
To understand that, I think you need to analyze the specific stud that failed. You would need to know if the material in the stud was to spec, and of course, you need to understand the details of how the spec material is forged. You would also need to know the conditions: was it previously used, number of heat cycles, the max temperature differential between cylinder and head stud.
I've read that in some alloys, higher silicone content causes mis-uniformities through-out the forging. I'm not saying Dilivar has high silicone content, just giving an example of needing to know the make-up of the material and understanding certain nuances about the forging process.
From what I understand , Porsche has changed the specification (make-up) of Dilivar at last one time. This is why Steve W and others recommend the 993tt studs, it's the latest recipe and has had very low failure rates.
Anyway, don't mean to give you an ear full, just really excited about your test as you can see.
tom1394racing 01-13-2011 03:02 AM
The problem with the Divalars is corrosion related fatigue failure.
Testing a new stud may not be indicative of the results you'll see in service.
lindy 911 01-13-2011 07:00 AM
To be clear, the studs I am sending V are the coated Dilivar bought from Porsche in 1992. They are not 993tt fully threaded studs but are the latest and greatest used in non-turbo motors. These studs were installed in a '78 SC case but never heat cycled. One stud broke an hour after torquing. We're talking less than 30 ft-lbs here fellas. It broke at the top of the thread down at the case.
This experience, for me at least, is enough to conclude that no matter how much you test or theorize these studs are absolute crap and unpredictable.
An interesting point: As a kid I put together lots of air-cooled motorcycle engines. The front of the cylinders faced the airflow and the back side did not. The exhaust also ran right next to the cylinders on one side and the other side was open to the air. The cylinder studs had exactly the same mechanical requirements as do our Porsche studs: clamp a single head to a single barrel. I NEVER saw a single stud failure!
Lindy
AlfonsoR 01-13-2011 02:31 PM
I think the point of the Porsche designed stud is to maintain the same clamping load through the whole temperature cycle as the engine goes from cold to warm and back to cold.
To do this, theoretically, you have to have a stud that has nearly the same thermal expansion rate as the cylinder. I say "nearly" because in the real world the temperature of the 4 studs and the cylinder will not be the same. With testing data, you may be able to compensate for this.
Anyway, what I am saying is that if you want to factor in thermal-rate-of-expansion, then your choice of alloys is probably pretty limited. I'm pretty sure Porsche chose Dilivar for that reason.
If on the other hand you want to throw that factor out the window, you could easily find material that is not prone to corrosion stress cracking (what it sounds like is happening to the old style dilivar) and can handle high temperatures. You could go with ASTM A193 (B16), with 125Ksi tensile strength or a duplex stainless like 17-4 with 160Ksi tensile. And I'm sure there are many more, those are just some that I have worked with on other type of equipment that come to mind.
The effects of having drastically different rates of thermal expansion or of having drastically different temperatures between the cylinder and the studs may be:
1. If the cylinder grows much faster than the studs, then studs will see an increase in clamping load. The increased stresses will transmit to the cylinder walls, which if not stout enough, can result in a wall that is not perfectly round as far as the piston rings see it. This effect can cause abnormal wear on the piston rings.
2. If the cylinder cools much faster than the studs, then the studs will see a decrease in the clamping load and will have the effect of studs which are not tightened to the correct torque specs. The possible effect could be a cylinder which will want to "walk". This may result loss of compression and possibly a lot more damage depending on how bad the issue is.
The holly grail is to not have stud failures and to maintain a consistent clamping load through the entire temperature cycle. I think it's a pretty tough trick, really.
brads911sc 01-13-2011 02:37 PM
Buy Supertec and call it a day... proven, cheaper than tt by 50%, better performance, testing already done, no failures... While I understand the desire to understand why something might fail, there is no way that you can duplicate the real world application on a consistent basis with all the real world variables... even Porsche couldn't duplicate the real world Head Stud performance in a test environment... if they did.. they would have never released these studs to the factory floor... how many sets did perfectly fine in a test environment... only to have a nightmare in the real world... we will never know but im sure if they had head studs snapping in the test environment they would have went back to the drawing board...
lindy 911 01-13-2011 02:40 PM
You hit the nail on the head with #2. The head walks and leaks on cool down if restarted too soon. Most of this had to do with the proximity of thermal reactors and their contribution to cooling, or lack thereof. Without reactors, dilivar simply complicates the issue. If it were necessary to match thermal expansions of clamped parts and bolts, they would need to use the dilivar on all four corners, not just the bottom.
Lindy
vytenis 01-13-2011 02:48 PM
Still figuring...
Thanks for the stud offers. I will try the 993 studs and use my steel and 1987 Dilivars first.
I want to test preload and possibly some thermal effects. I'm thinking I can measure coefficient of thermal expansionm of studs and cylinders in my (wife's) oven to compare to published values.
Don't know and can't test stud properties and don't know actual temperatures.
Thinking about strain gages and a dial indicator to monitor preload. Instron machine I was looking at won't handle the loads needed for a stud.
I'll be back here in a few days with a plan to be shot at.
"V"
vytenis 01-13-2011 02:59 PM
You are absolutely right. Nobody is going to come close to the body of knowledge or expertise amassed by Porsche with this I might say embarrasing head stud problem.
I don't plan to to a dissertation, but as a mechanical engineer, there is a certain curiosity.
"V"
wdfifteen 11-29-2015 06:02 AM
To be clear on this, Porsche used Dilivar on the bottom only?
My engine is an '88 Carrera. I'm trying not to break the bank on this valve job/while you are in there project. Should I replace the lower studs or all of them?
tom1394racing 11-29-2015 06:09 AM
You only need to replace the lower studs. The tops are steel and will be fine.
PM me if you would like to purchase a set of lower steel studs.
safe 11-30-2015 03:01 AM
Yes, I had one break on my 84 Carrera engine a few years ago. Just one and that stud had no plating left.
