-   -   Tool Help: 1969 911T Refresh (http://forums.pelicanparts.com/911-engine-rebuilding-forum/583930-tool-help-1969-911t-refresh.html)
kevin_fisher2.0 01-06-2011 09:31 AM
Hi all,
I'm refreshing the engine compartment on a '69 911T and while I'm doing so I'd like to clean up some of the engine components as well. I'll need some tools so thought I'd see if anyone would like to part with the following:
- Engine Stand Adapter ring
- Engine hoist (how much capacity do I need?)
- Flywheel bolt tool
- Clutch alignment tool
- Valve adjust tool (with or without blades)
- Synchrometer
- Flywheel lock
- Oil seal installation tool - pulley and flywheel sides
Thanks,
Kevin
