-   -   911 SC with broken head studs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/584667-911-sc-broken-head-studs.html)
Nicks911 01-10-2011 11:54 AM
Thinking about options here. As the motor has ~140K miles un it I figure a full rebuild is not a bad idea. I was thinking about building a 3.2 or 3.3 Short stroke with 9.5 compression ratio. I was wondering if anyone had used the motronic system from a 3.2 Carerra as the induction system for a motor like this?
Nick
Flat6pac 01-10-2011 03:23 PM
Motronic sensors wont bolt to the case but a Carrera case will work as long as your building and the 3.0 case has decent value to defray the cost.
Bruce
