-   -   Cylinder Compression Issue (http://forums.pelicanparts.com/911-engine-rebuilding-forum/585410-cylinder-compression-issue.html)
pemz0r 01-13-2011 10:44 PM
Old cylinders and new pistons. Cylinders 1, 2, 3 have exactly 50% less compression than cylinders 4, 5, 6. Could the valves be adjusted wrong or is the cam timing off.... or any ideas?
Flat6pac 01-14-2011 09:42 AM
Did you open your throttles to the other side>?
pemz0r 01-14-2011 11:26 AM
yea they are open.
#1 85psi
#2 57psi
#3 57psi
#4 115psi
#5 118psi
#6 116psi
Haven't looked at the valves yet, so I am hoping that is the issue
pemz0r 01-14-2011 09:35 PM
double checked the throttles....closed.
that solved the problem, thx
